FORScan Crowdsourced Wiki
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Did the speed limit sign not get added to the main list?
Steering wheel switch packs:
SCCM:
Left switch 724-02-01 xxXx.xxxx.xxxx -- 1 = Std cruise, 2 = ACC
Right switch 724-02-01 xxxX.xxx.xxxx -- 0 = Lariat media, 1 = Std audio
These are in the configuration menus for the SCCM using the switch part numbers as well as a couple of other options.
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
Couple question regarding ForScan... I did a quick search but didn't find anything.
1) can you save a setting before you change it?
2) can it be reset so that Ford doesn't know we are changing settings?
3) is there a way to back up the setting you have changed (ie im taking the truck in for service and I have 10 settings I have changed can I save these as one event or do I have to make 10 changes once the truck is done and Im back home?
Why Ford thought it's a great idea to turn the damn radio off after 15 minutes annoys the piss out of me... :) I understand this can be fixed in ForScan... this is enough of a reason to get this...
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Why Ford thought it a great idea to turn the damn radio off after 15 minutes annoys the piss out of me... :) I understand this can be fixed in ForScan... this is enough of a reason to get this...
Yes.
Yes.
Yes.
You can go into the "ASBUILT" modules, which will let you save the full hex to a file you can save on your computer. You can also load from these files at any time.
The only downside I've found so far is that you can't do this from the GUI options pages, only the ASBUILT hex pages. (But note, that regardless of where you change the settings, using the GUI options or HEX, they will always be reflected in the HEX pages you save/load.)
JimH
Palm Coast, FL
When I took my 2020 in for an oil change, nothing was said about the Raptor screen, and they didn't reset any of my other changes...
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
Yes.
Yes.
Yes.
WOW that was fast Thank you Sir! Ordering my adapter today.. Awesome Thank you!
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
okay last question for now I assume I want an extended license?
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I opted for a 1 year license. I could've likely gotten away with two 30-day licenses from them, but the $10 for the year is way worth it to support what they're doing and give me time to tinker at my own pace.
ProtonDecay
Bay Area, California
'21 Ford Ranger XLT
Agreed - I tend to support those who bring value to the table, and Forscan has given me way more value than the cost of a license. I encourage others who have benefited from this work to do the same. :)
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
I bought the lifetime....if it fixes a couple things that annoy me it's worth it!
Frank
Windsor
2019 Ranger Lariat Sport 4x4
Is there a GUI for adding heated seats icon to the Home screen or secondary menu?
Hirnlego
SC
2019 Ford Ranger XLT 302A
It is called “Seat Button Icon” adds heat control buttons to HOME/Climate Controls on head unit display
As Built 7D0-01-01 xxxx xxxx x3xx Enables
