Ford Pass Not Updating Oil Life
Chris Frazier
Construction
Had oil change at independent shop. The oil life in Ford Pass not updating.
Any advice? Thanks
brroberts
Randy
Overbrook, KS
audio / semi retired
Mine takes time too, but eventually it picks it up.
Joeiconic
Ford pass won’t update unless either you or the shop enters the info and an independent shop won’t have the ability (or desire) to do it. If you have your receipt, you can do it yourself.
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
I’d suggest changing your oil by mileage not by the oil life meter. My 2 cents.
Dgc333
21 Ranger Lariat
Any advice? Thanks
Did the shop reset the oil life in the truck? Ford Pass is going to reflect what the truck says and if the shop did not reset Ford Pass will not reflect the oil change.
Friday yet?
‘23 Lariat Tremor, Focus ST
I'd bet a beer and some wings this is the issue.
Yep - You can reset it yourself easily - just takes a few button presses. with the steering wheel buttons.
But sometimes Ford Pass is a little slow in updating, you can see the last update time in the Ford Pass - This shows the last time Ford Pass - Communicated with the truck.
Chris Frazier
Construction
I will be doing that too. Ford says it is 10k miles, however, Ive seen where some say that oil should be changed 3k or 4k, despite synthetic oil being used?
Motorpsychology
Prescott, WI
Vagabond
I do that, too. My Ranger is either parked or driven 50-100 miles, and I change oil and rotate tires every 6,000 mi (Quick Lane Works PKG). My 2009 Mariner is the grocery getter, often only driven les than five miles at a time so it gets a works Pkg every 3,000.
The Ranger still shows ~60% oil life, but the Mariner will be down to 5% or less, so whatever voodoo it do is pretty accurate.
Tremot Trent
Trent
Kansas
2022 Tremor
Driver
Yes there is dash control entry, yet with Ford Pass, Few vids out there, yet basically turn on to accessory, (I have key, not push button start) push down brake/fuel peddle, (hold down) I count to 60, will usually within 30 minutes update, if not, turn phone off/on, updates app. Ford Pass seems slow on updates.
Jamie Jack
Jamie
Kelowna, British Columbia
I do both. I watch the oil life indicator and change it out at 20% for a cushion of safety.
