Fake engine sounds?
rooster
BOS
STX FX4 SuperCrew
engineering systems admin
I’ll give real and ducted engine noise a pass, but artificial noise .... no pass here.
Denver133
Denver133
Denver, CO
2019 Ranger on order
Here's an example of the fake noise being played in the RS with the engine off. The boys over at COBB figured out how to play them at will. BTW, in the RS, to get rid of it, its as easy as unplugging a box in the trunk. Its not from the actual engine, its all fake.
HAHAHA!
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
Depends on what you're after but yeah, I'm with you. I hope it's a simple as a fuse.
Tomsriv
Tom
Camarillo, CA
2006 Dodge Magnum RT (345 V8), 1971 Buick Riviera (455 V8)
Maybe we should all get a Soundracer V8.
Rinn69
N. Central Iowa
Retired USAF MSgt
djrobb
Alexandria,Va
Anyone figure out how to disable the pumped in engine noise? I don’t mind the sound but I have a light buzzing noise and I want to see if it’s the root of the problem.
rangerdanger
SF Bay Area
t4thfavor
Chance
I haven't noticed any noise really. Maybe, just maybe under WOT, but I can't really tell. Thus I have not tried to find the fabled "white fuse #27" as it is referred to in the FoRS.
Maybe if I could get my hands on some time machine juice I could go back and not partially ruin my hearing (I'm only 35) when I was 17 and stupid.
Fordstanger
DMV
2016 GT350, 1969 ProStreet Mustang, 94 Lightning, 2019 XLT Ranger
Got same noise here. No, it’s not the TSB trans whine. It’s a very light buzzing sound.
My Shelby GT350 has pumped in noise and was defeated only via computer. Most who defeated it turned it back on. I left it alone.
djrobb
Alexandria,Va
Hopefully we find a solution. It is annoying at low speeds. Can’t really hear it after a bit in the truck.
t4thfavor
Chance
You could pull the entire APU/Radio fuse, and see if the whine noise is still present.
R G
SoCal
35 MG PB thru 2011 R8
Can’t be all bad Porsche does it.
I remember when Porsche sold their Motor Sound Kit for the 993 generation 911s. It was a super expensive airbox lid with holes in it. I accomplished the task on my stock airbox lid with a hole saw. Sound was incredible, and it was real. No matter how good a fake sound one makes, it's fake. I would rather take the engine package sound at face value.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
I honestly can't tell if it's there or not.
t4thfavor
Chance
On the Focus ST, there is (was?) an Active Sound Symposer (ASS for short) connected to the intake manifold with a diaphragm. It would take the induction noises, and put them straight into a port on the firewall, There was a valve that opened and closed progressively with the throttle position, if you remove that valve, it was really throaty all the time. However, I didn't like induction noises, so I bought an open end filter, created a plug for the open end that had a hose barb, and connected that to the ASS. Once connected, all the choo choo's of the turbo came directly into the cabin bypassing any sound deadening, it was nice :)
Then, they did away with the mechanical ASS, and started pumping noise through the speakers. It doesn't matter to me, but I would like to be able to change the station to "choo choo" from "vroom vroom".
Chad Cyr
Chad
Maine, USA
2019 Ford Ranger Lariat FX4
Did you find out what was causing your buzzing sound? I believe I have the same issue with my truck... started about a week or so ago. Engine makes a light buzzing sound at lower speeds or when accelerating. Brought my truck to my dealer and two techs had their heads in the engine bay and they could hear it, but not isolate it. I'm supposed to drop the truck off on Wednesday for them to delve deeper into the noise. Thanks.
