Gen5RangerPegasus
- Thread starter
- #1
Terrain Management.
I do not believe this is a straight forward mod that some claim it is. I have read that if you buy a Terrain Management Switch, install in it your Ranger, and toggle the "Selectable Drive Mode" to "Enable" in the IPC module using Forscan that you suddenly have Terrain Management. I believe there are further steps that need to be taken in order for this to truly work. Sadly, I think many Ranger Enthusiasts are selecting drive modes with no real change to driving behavior.
Toggles I believe need to be switched:
ABS Module:
- Brake Control
(*Needs to be switched to, "ABS/ESP/RSC/TERRAIN" to handle the braking calibration while using different driving modes)
PCM Module:
- Terrain Mode Management
(Needs to be switched to "All Terrain Control Module" to recognize the module commands)
IPC Module:
- Terrain Management/Selectable Drive Mode
(Needs to be Enabled to recieve prompts from the Terrain Management System)
Further toggles In the IPC I believe need to be turned on:
"Terrain Management Type" (will need to be selected to "Type 1,2, or 3") and finally "AdvanceTrac Control" to "Enabled".
I am not certain that Terrain Management Type needs to be toggled or AdvancedTrac Control as it may pertain to trail control, which cannot be activated using Forscan because of hardcoded firmware in the ABS module from the factory. It may be the same for Terrain Management which would instantly kill this mod.
The only way to truly know is to compare module toggles/As-Built Data. Is anyone willing to share their configurations from a truck equipped from the factory with Terrain Management?
On a side quest I am also looking for the BCM toggle for the elocker. If anyone can see the toggle in that module please let me know as I cannot find it in mine. I only found the toggle in my ABS module and my ICP module.
Let's Talk.
ABS Module:
- Brake Control
PCM Module:
IPC Module:
Let's Talk.
