Eibach Pro lift kit on 2WD
SubVet
SubVet
Myrtle Beach
AFTER INSTALL of the Eibach pro Lift Kit WITHOUT the kit springs.
Measurements from the center caps to fender
Front 23" and rear 24"
From floor to fender
Front 38" rear 39"
1" rake which is nice when hosing out the bed,
MotoWojo
Mustang
Front 38" rear 39"
So, was the front lifted with the stock springs, with the clip in the lowest position? Waiting on my order from Stage 3, they claim that Eibach never received my order, so they resent it. Good thing I was up early on Black Friday, putting my order in, to beat the rush? I have some 265//70R18s ready to be mounted on my stock rims. I am hoping I can fit them without lifting, but I would rather wait until I got the Eibachs, just in case.
SubVet
SubVet
Myrtle Beach
Yes. The Eibach is basically a lift kit. If you use the Eibach springs you will have 3" of lift. If you use the stock springs you get from 0-2.25" of lift. I would be interested in the tires you are running without trimming anything in the wheel well.
FULLSCALE
Adam
Ontario, Canada
You can get the full 3” with the stock springs too but the ride will be stiff as the springs will have the most preload on them. @SubVet, if you’re on the 2.25” setting I believe you’d be using the second groove from the top.
SubVet
SubVet
Myrtle Beach
I think that's right, Adam. I tried to get under there with a flashlight to see what notch they put it on I believe you're right. Yeah if I want a 3in I would just use the Eibach springs. Absolutely no sense in using stock Springs if you want 3 inches of lift
FULLSCALE
Adam
Ontario, Canada
I agree 100%. I’m not sure why they would even make it an option.
joeb427
I would think because some people just buy the shocks and can go 3" without the springs.
MotoWojo
Mustang
On the tire size, I am going by the what another member has stated in this thread:
https://www.ranger5g.com/forum/threads/towing-a-19-airstream.4291/page-3#post-83456
He fit the 265/70R18 on stock wheels with no lift or trimming.
joeb427
Installed rear's today. NO modification to anything was needed 4 bolts easy install.
No issue with bushings (if 2wd) with Eibach bolts being bigger?
nbeninati
19' Ranger Lariat
4x2 or 4x4 ? Help the ride any? Thanks
2WD. Did not drive to much but smoothed out ride so far. Going to install fronts when I find time.
No issues fit perfectly. I bought the front and rear kit no bolts come with the kit for the rears just 4 sets for the front.
Used the stock bolts/nuts.
Torque - 52 ft -lbs according to ford manual if any was wondering.
joeb427
These were the pics I took under there today. I only got the Eibach rears. I reused the bolts from the factory shocks. No new bolts came with the rear Eibach springs. These fit with no modification using the factory bolts.
I see the bushings in SubVets pics. I don’t think I had those on my stock truck but I’ll check tomorrow.
Dealer installed front Eibach struts set at 2.25" and rear shocks were installed like yours,DJ. Dust cover on top.
No modifications were needed here also on the rear installation.
MotoWojo
Mustang
Well, after Stage 3 lost my first order that I placed on Black Friday, the Fedex truck finally dropped off a box from Eibach on Wednesday. I opened the boxes, which are marked correctly with 2 fronts & 2 rears, to find I received 4 fronts. I called Stage 3 and they told me I had to send an email to their RMA department, with pictures, and that I should hear back from them in 1-2 weeks to find out how to resolve this! Totally unacceptable! I have never in my 56 years received the wrong item and had to wait to get an RMA and most respectable businesses would ship out the correct item as soon as my RMA items shipped. They laid the blame on Eibach, but I reminded them I didn't buy them from Eibach, I bought them from Stage 3 Motorsports. I am guessing at this rate it will be at least several weeks before this gets corrected. Well at least I have the fronts, I hope they are for a 2019 Ranger.
Did anyone receive 4 rear shocks?
MotoWojo
Mustang
Looking at the 4 "front" shocks I received (incorrectly), there is no hardware in the 2 boxes that were marked as rears. The 2 boxes that were marked as fronts have everything except what i highlighted below, can anyone tell me if they received those items?
