Dorman transmission pan
where are you getting the ppe pan so cheap ? the ppe is 312.00 dorman is $ 52.79... fitz stick is 200 with shipping ..... either 512.00 or 252.79 little more than $100 ..
He is using the "Common Core" Math to figure it out
AndyMedic
Andy
2021 Ford Ranger
Paramedic
I would not worry about a plastic pan at all off-roading. Almost anyone who really would risk damaging a pan will have full skids. If I puncture my pan I have a lot of issues going on with full steel skids.
I would and will consider this on my next transmission service. I don’t care about extra capacity, but extra cooling with the fins is possibly worth it.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Maybe you haven't priced the B&M dipstick? ?
Grish
Micheal
Oklahoma
2019 Ranger STX 4x4
I can’t thank y’all enough on the discussions about the Dorman pan. I went ahead and ordered it along with filter, fluid and got on the waiting list for the Fitzstick. I didn’t feel the need for the larger pan and its superior cooling capacity as I have the big diesel for my towing. This little truck is just a back and forth to work with the occasional road trips.
Hopefully I offered help to at least one person that wasn’t aware of it. Maybe was on the fence like myself and decided it’s good enough for him/her just to gain the drain plug.
Langwilliams
Langley
Lorain, Ohio
I saw a thread about them on a bronco page. They were unsure of Dorman fit quality but no one actually had first hand experience with the part. Looks like a good solution for those of us that just want easier fluid an filter changes.
TJC
I can't speak to this particular part, but I have purchased several Dorman parts including a driveshaft for my 2005 Ranger (aluminum just like the factory part) and the steel transmission pan with the plug for easy maintenance. Both were good solid products and I have no hesitation about purchasing Dorman products.
I think the pan will be fine for what it is. I wish it had been available when I purchased my PPE Deep pan. Choices and options are good things. I probably would have still purchased the PPE, but only because my trannny is bipolar. Great in the winter, and substandard in the summer.
I just finished replacing the hydraulic hoses on my Bendpak lift (they lasted 17 years!). Tomorrow I remove the lift tank and clean it , then replace the fluid and test. Once it is operational, it is change the oil in one car and install the PPE pan, filter and fluid in the Ranger.
Grish
Micheal
Oklahoma
2019 Ranger STX 4x4
Once I get everything in and installed, I’ll be sure to come back with an update and personal opinion on it. Might be spring time until I have the dipstick but I’ll get it eventually.
Langwilliams
Langley
Lorain, Ohio
I'm used to being the guinea pig an trying the new stuff but I'm getting old an grumpy an don't want to crawl under the bronco a second time to replace it lol.
Grish
Micheal
Oklahoma
2019 Ranger STX 4x4
Same brother. Hurts too much the next day ?
Langwilliams
Langley
Lorain, Ohio
If a good deal on a lift falls in my lap on Marketplace I might get it but I avoid working on stuff now, it used to be a hobby, now it's a pain.
Langwilliams
Langley
Lorain, Ohio
Since you have to remove the OE pan to replace it with the Dorman, why not just install one of these instead and save some $$.
https://www.amazon.com/80250-Automa...F_OAgvS8wdGn1_rIfNgnsDFtLFq2X92kaAhVNEALw_wcB
Because that has a higher chance of leaking. That is why. Those are ok on steel pans. Plastic is questionable.
I would be afraid of it leaking too an it looks like the last quarter inch or so of the fluid wouldn't drain with the inner nut in the way possibly leaving a lot of sludge in the pan.
RAYJAY
UNION DALE PA
2020 ranger pickup 2019 subaru
please keep us updated on the fit and finish of the dorman pan.
21rangerCactus
Louisiana
2021 Ranger XLT
Self employed
I have the Fitz stick and I'd rather spend my money a fluid pump. No need for a drain plug.
