Does your Ranger have vibration at take off, what did you do?
navsnipe
Rockland County, NY
I have had my Ranger a day short of two weeks. I have about 450 miles on it. I really like it except the driveline vibration at take off, and stop and go at low speeds.
Is this common? What did you do to fix it? Did you just live with it? Did you have the TSB 20-2277 done on it?
I have read through and been active on this thread https://www.ranger5g.com/forum/thre...vibration-when-accelerating-from-a-stop.8908/ but would like to get an idea how widespread this is.
Hi Dave,
To my knowledge...it is a mixed bag of results, primarily due to spotty dealership expertise for example. There are folks that have shimmed their center bearing with good results and others that report the TSB fix worked....Some reported the TSB did not help....again likely dealer competence or lack there of...
navsnipe
Rockland County, NY
Thanks Phil.
I was trying to figure out how to setup a poll but figured this post would hopefully get some info going. Hope for more feedback activity tonight.
Thanks Phil.
Hi Dave
Start up shudder is a dynamic event. Stick with me here.... When you accelerate The rear axle pinion rotates upward, how much depends on how hard you accelerate. This change in pinion angle results in a change in the driveline angle which may induce a 2nd order driveline vibration which in the cab you perceive as a momentary shudder. What the manufacturer tries to do is determine a static pinion angle that when the pinion lifts, does not induce this 2nd order vibration or shudder. So the TSB is an attempt to change the pinion angle slightly to hopefully stop the driveline angle change to induce shudder. The angle measurements were determined by Ford Engineering to id those Rangers that are borderline in spec and have shudder or out of spec.
Hopefully this makes sense...
navsnipe
Rockland County, NY
Hi Dave
Phil,
I follow what you are saying and agree 100%. You have provided some great insight to this. We have already been conversing on the shudder TSB thread. I was hoping with this thread in the General topic to find out just how many people are having this issue. I think I may have confused things a bit.
Anne
Anne
Upstate NY
Red Ranger
Hi Dave
You wicked ROCK, Phil. I love reading your wisdom! I don't totally get stuff, but I like it!?
Ace Holliday
Scott K
South Kalifornikstan
2019 Ranger XLT Super Crew
I have 6000 miles on my 2019 Super Crew. I get a minor shudder once in a while. It actually seems like it is getting better as the miles accumulate. It bothered me a bit at first but now I rarely notice it. I think that other trucks may do it worse than what mine does.
If it bothered me I would take it in to have the TSB performed. Couldn't hurt......I hope.
HI Scott,
If you do have the TSB performed, It could possibly make it worse if the dealer tech is careless. However, the shim can be removed and you would be back to current configuration. Of the shims in the kit, only one specific angle change should be needed. The kit is pricey as it includes quite a few shimming options.
Ace Holliday
Scott K
HI Scott,
Thanks for the heads up. At this point I am just going to leave it alone Phil. It currently only does it once in awhile and even when I feel it it is very subtle.
As I said earlier it seems like it is quite a bit better than when it was new. I have 6000 miles on the odometer. I wonder if anyone else has noticed an improvement over time?
JaketheMus
Jacob
Hawaii
2019 Ford ranger
Transit
I deactivated the auto start/stop from day one. It’s a fully boxed ladder framed 4x4 truck, if I wanted gas mileage I would’ve got the Honda. I also drop it into s mode hit the + button on shifter and wind it out like a manual every time I drive her. No shudder issue. 15k on my 2019 Ford Ranger 4x4 Lariat. Heavily modded.
Progeny2021
Charlotte, NC
I'm getting some vibration, but the 'bounce' gets my attention every time!
Aonarch
Alec
North GA/ Montana
Mine does this as well. If I end up caring enough, I'll go with a Woodys driveshaft.
Its around 10 mph.
I have a feeling it is like a spinning top, they stabilize at speed. Low speed the two piece join probably wobbles about.
Cabose-1
Eli
Student
Mine does this as well, as the knocking when coming to a slow stop.
I kniw many others have chimedbin on there displeasure with this and so on.
Opinions are like assholes, everyone has one
I have a truck, sobit doesn't bother me much. Id complain if it was on my deville, or escalade.
And with a trailer attached, well, the hitch makes a lot of noise and movement anyway, so i dont notice it.
if i had a gen-y torsion hitch id feel less on the hitch.
So basically, i just learn to live with it
My mazda 3, has a really good ride compared to my Ranger. Its a car.
