HarryD
- Joined
- Sep 3, 2019
- Threads
- 13
- Messages
- 197
- Reaction score
- 129
- Location
- Western MA
- Vehicle(s)
- 2020 Ranger 4X4 SuperCrew Magnetic Lariat Sport
I have not felt the vibration at takeoff, but on a smooth road I have definitely felt the driveshaft vibration.
As has been suggested by our Australian member, 4Wheeler, this vibration seems to be related to the relative lift and resulting driveshaft angle. I noticed that Ford has placed 8mm (5/16") shims under the leaf spring, one on the right and two on the left to adjust the frame tilt (I am assuming). This essentially results in a very minor lift.
For my initial attempt to shim the Center Bearing, I bought some 4mm X 40mm stainless steel stock to cut shims. I adjusted the bolt hole location to match my particular application (your position may well vary). I only added one shim because to add more I would need longer bolts. I am looking for 10mm - 1.5 X 50mm bolts with a 15mm hex and a quite large flange head. The OEM ones include an integral washer with a 27mm O.D.
Well, with the single shims installed, I drove to the smooth stretch of highway that initially brought the vibration to my attention, and to my somewhat surprise, I did not feel the vibration anymore, just the minor road undulations that are present here in the best of roads.
I would still like to try two shims if I can locate the bolts needed just to see what, if any, difference can be felt.
