Disable fake engine noise
I checked with my audiologist and found out my hearing aids will generate a little white noise to counteract certain frequency sounds. That's what I'm hearing when the enhanced noise gets louder. I hope disabling the enhancement is an easy task.
Good luck with the dealer. Please report back if you are successful. There are a lot of people here that want it disabled, and so far I haven't heard of any success in doing it.
nutzNboltz
Columbus, Ohio
2020 Ranger Supercab STX
Professional Idiot
If this could be isolated to a variable soundtrack, that would be great! I would change it to the sound of The Jetsons car.
THLONE
Thom
Tucson,AZ
internet wise guy
Yes and if we could put the sound of a straight pipe V8 on the outside.
geophb
Mechanical Engineer
I have been working with forscan for few months to get this solved. They reached out to me last night with another test version to try. I will test it out this weekend and report back.
I don't have my hopes up. The problem is that the Engine sound enhancement (ESE) or Fake engine noise is controlled by the DACMC module. In the ranger the DACMC is integral to the ACM module based on some technical service manuals I have found. So the DACMC doesn't come up as a separate module on the canbus network, therefore not configurable.
BUT
Im hoping the DACMC module configuration data is combined into the ACM module, making the previous paragraph irrelevant. This will be the saving grace.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Or the start of 2001 a Space Odyssey !
geophb
Mechanical Engineer
Don't know if this has been posted before. This is the ESE on the focus rs that COBB tuning got to play without driving. ?
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
BUT
I've asked multiple times but they've never replied about the quick tap turn signal counts. Can you ask them about that one as well?
geophb
Mechanical Engineer
I have done research on this before. Ive found that its an issue on the 2014+ focus, escape, and now rangers. Something about forscan can't figure out how to get it work with central config.
F-series, fusion, taurus etc is no prob.
Known spreadsheets refer to 724-01-01 in the SCCM BUT the value to change, well in my ranger atleast, is xxxx-x0xx-xxxx. Which is supposed to be 1 flash but mine flashes 3x i beleive. Changing the value in mine resulted in no change to flash count.
I kinda gave up on it, and from what ive found I think the forscan team did too. Hopefully the ESE doesnt have the same fate.
BassRanger
Al
Oklahoma
Goodyear
I ended up replacing the factory amp to get rid of the noise. I noticed it from the first test drive. Didn't bother me until I installed subs.
None of the Forscan patches worked for me.
geophb
Mechanical Engineer
Same, the sub makes it almost like you're driving over rumble strips. Didn't care or hardly notice it before the sub unless I was trying.
You have B&O system? NonB&O systems have the amp inside of the ACM.
Reactions: EJH
nutzNboltz
Columbus, Ohio
Professional Idiot
Is this the ACM? Just curious.
nutzNboltz
Columbus, Ohio
Professional Idiot
Looks like it. The display and "headunit" are no longer one piece.
Well I guess no Jetson car sounds for me. It just gathers dust on a shelf now. Still interested in this thread though.
geophb
Mechanical Engineer
It worked! :rockon:
Forscan figured it out! I don't know how they do it but the fake noise is finally disabled.
My god, Forscan is part of the reason I buy fords. ??
I will let them know that the test build they sent me worked and then I assume they will roll out an update in the future to include it in the main build.
Couple things:
- I checked the as-built after I disabled via the config section. And if I remember correctly, what changed was 727-01-01 xxxx-"X"xxx-xxx. Mine subtracted two when it was disabled. Went from a "3" to a "1". That was the only thing I noticed, I may have to double check. I would probly just wait till they add it to the main config section though.
See Post #106 (my next one)
- I haven't noticed anything else changed that shouldn't have, and everything works as it should. Just without the fake engine noise. Sometimes odd things can happen.
- Mine (an XLT) does not have ANC (active noise canceling) as far as I know, mine stock shows disabled in all the ANC menus in the test build, and also shows ANC mic as disabled/unequipped. Lariats may be different and B&O system may be different, I don't know.
I do know that I didn't have a mic in the headliner, atleast i didn't see one, when I had it down to put in sound deadening on the roof of the cab. In other fords the ANC mic is in the headliner for the most part.
micl9
Apex, NC
It worked! :rockon:
Couple things:
- Mine does not have ANC (active noise canceling) as far as I know, mine stock shows disabled in all the ANC menus in the test build, and also shows ANC mic as disabled/unequipped. Lariats may be different and B&O system may be different, I don't know.
Nice job!
If you saved a version before and after the change you can use Windows command line FC (file compare) to see whats different. It will compare the backup files and show you text results, you can also redirect to a file for ex
Code:
FC xxx.abt yyy.abt > FCresults.txt
