Disable fake engine noise
Porpoise Hork
Bret
Houston
IT
Was enabled on mine as well even though I really never noticed it until I disabled today. I have a 2021 Lariat Tremor. One unexpected change that happened when I disabled was that the chimes switched from the speakers to the dash, which I find kind of annoying.
Random changes in Forscan will do that. It has something to do with the BCM module not being fully loaded when the system initiates the chime and defaults to the cluster speaker. Most of the time the chimes will revert back to the door speakers after a few key start/stop cycles. If it still does not revert back you can reset it by pressing and holding the left side OK button on the wheel while starting the truck, keep holding the Ok button for a few seconds after starting. At this point the chime should switch from internal speaker back to the stereos speakers. I have had to do this a couple times when I made multiple changes in the BCM and the chime switched and would not revert on its own.
gwhalin
Greg
New York
Yep, it reset itself by the next morning. Good to know the reset procedure. Thanks!
