Disable movement lockout
RangerJeff
TheJeffness
2019 Ranger XL STX
has anyone found a way to disable the lockout when vehicle is moving? I know it’s a safety feature but it’s aggravating that passengers can’t access all my pandora stations until we stop.
DBaz
Dan
'19 Ford Ranger Lariat FX4
There's a Forscan setting "Navigation in Motion" that allows you to change nav destinations, do texting, and change settings while driving.
I've done it and it works well. Haven't tried it with pandora but imagine it would work.
There's a Forscan thread that explains how to make changes.
Setting code:
APIM 7D0-02-01
5753 xxxx xxxx
RangerJeff
RangerJeff
TheJeffness
2019 Ranger XL STX
Setting code:
APIM 7D0-02-01
5753 xxxx xxxx
Thank you.
Hi Jeff,
Inside the company we call this feature Detroit Locks. If you are in Detroit city limits, and you have unlocked doors, you will likely be car jacked. A key feature for living in the Detroit area.
RangerJeff
RangerJeff
TheJeffness
2019 Ranger XL STX
Hi Jeff,
Thank you for the reply, but I think we are talking about two different features. I don’t mind the doors locking. I just don’t want the radio to limit functions because the vehicle is in motion. For example, I can’t scroll through pandora stations, and neither can a passenger until the car is stopped. It gives a message something like “For your safety, some options have been disabled while vehicle is in motion”. I want to turn that off
Hi Jeff,
Okay...got it....I understand now....Sigh...thick skull on this one....Wish I could help, but not able to at this time... Friend from Autonomous Vehicles at Ford will be visiting this winter and bringing his laptop so we can peer into the ECU etc...
best,
t4thfavor
Chance
You can disable this movement lock on the Navigation system with Forscan by setting a different locale. I'm not sure if it corrects the issue with Pandora, but it might be worth a try.
It's completely unacceptable for this to occur as the voice commands are nowhere near sufficient, and it requires someone to either pull over or exit the expressway EVEN IF THERE IS A PASSENGER...
People who design cars should be required to own and use a car...
RangerCat
Brian
Kansas
My biggest beef is the text responses. Look, I TOTALLY agree that you should not text a drive. But, since the system let's me read the texts, it should allow me to respond with something other than it's 15 poorly thought out responses. I should either be able to response with voice or I should be able to set my own preset responses. Just Sayin'...
t4thfavor
Chance
Apple Car Play lets me respond to texts, so it's stupid that Ford couldn't add a speech to text reply feature.
RangerJeff
RangerJeff
TheJeffness
2019 Ranger XL STX
Thank you. And I couldn’t have said it better myself.
Stic-o
Lake View Terrace, CA
Android auto also let's you respond to text, or even start a text too.
Just say "hey google, send text message"
RangerCat
Brian
Kansas
Yeah, the problem is, if you use Android auto, you can't use all of the other Sync3 features that I think are great. I like the built in nav better than Google maps and really like the audio GUI. Except for being able to text, I find AA to be rather weak. Not to mention that, when you use AA, it uses your phone mic for calls and not the mic that is above you in the headliner. It makes it sound like you are in a bucket. Ugh!
Stic-o
You switch in and out of AA easy enough by just pushing the home button. I don't have nav, because I had no need for it with AA. Let me know how good your factory one works after a few years. My '16 Explorer factory nav stopped working just after the warranty expired.
I don't think that's correct about AA using the phone mic, as I always leave my phone in the lower console, and nobody has ever complained about the call quality. Maybe it's your phone.
gmadams
Gary
2019 Ranger Super Crew XLT 4X4
Setting code:
APIM 7D0-02-01
5753 xxxx xxxx
I just made this change. One obvious difference is that the Language is now "UK" instead of "US". "Favorites" is now spelled "Favourites". It does allow me to choose a destination while in motion.
