Dash Rattle, Help!
Ranger X3
Matthew
Sedona AZ
2019 Ranger Supercab Lariat FX4
Hi all,
I've had this dash rattle since day one, the dealer can't figure it out. It's on the driver side next to the defrost vent. Happens at all speeds, mostly on colder days. I'm assuming that maybe there is a loose clip tucked up in there?
Thanks
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Have you tried using some force and push down on that area and see if something isn’t clipped in all the way? Otherwise I would just tear it all out and inspect. Nothing else to do really.
Ranger X3
Ranger X3
Matthew
Sedona AZ
Yup, given it the push and pull treatment, and some taps with a rubber mallet.
slowmachine
New Hampshire
A recurring rattle drove me nuts for months before I removed everything that could be removed from the cab. It was my eyeglasses, in the overhead storage. It’s very difficult to determine the direction of a sound like this. Removing everything, and enlisting the help of a passenger (or driver) makes it easier to find the source.
fortywater12
Evan
Sacramento, CA
I have the same rattle - it goes away if I press down on the dash defrost trim on the drivers side. As soon as I let go, it comes back. Mostly on colder days for me as well.
I took it into the dealer a couple of weeks ago and they agreed its probably the plastic trim thermally contracting and expanding, resulting in a rattle. I asked if they could shim it or add a piece of foam under it to keep it from rattling and they said no.
Very annoying.
McLeadslinger
Trevor
Pikeville NC
Aircraft Electrician
I have the same rattle. Drives me nuts.
Zeroedin
Matt
USA
2021 Ford Ranger Roush Edition
Unfortunately, I can’t offer the OP any useful advice (I’m assuming he’s narrowed down the source/area)….just thought I’d mention I had the same issue with a pair of cheaters I had forgotten were even in the truck. Took me weeks to figure it out, but in my own defense I wasn’t actively looking for the source. Now I keep ‘em wrapped in a cloth.
Still “passively” looking for a way to keep the passenger seatbelt from rattling, lol.
Hi Folks,
Okay...mentioned many times before, but new folks may not have read this:
Pick up a cheap Mechanics stethoscope from an autoparts store or Amazon etc. Discard the diaphragm and metal rod probe. You now have a very directional device to help you pinpoint the source of the noise.
daniel3507
Oklahoma
2019 Ranger XLT Sport 4x4
Very annoying.
Exact same location as my rattle and only in cold weather
OrangeStreak
New Mexico
I know what you're going through, and you hope can find the solution to that! My 2011 Ranger had a dash rattle that occurred when going over bumpy roads but was intermittent...constant annoyance :angry: I tried everything I could think of and checked the Internet for sources to help...nothing worked so the buyer inherited the rattle. It is a relief not to have any rattles or noises in the 2020 :clap:
Kirby808
Michael
Nelson British Columbia
Ford Ranger
Electrician
I’ve had this happen. Only real fix I could come up with was having the dealer take the dash off and fix it. Took them a couple try’s but they ended up putting a bunch of foam and who knows what in there. Million times better. Only took them 2 try’s. Mine was at the point where if I would knock on the driver side dash I could clearly hear whatever it was rattling in there, cold days were the worst. Very annoying.
Another redneck option just fill er with spray foam and call er good ?
halligan1201
Byron, IL
2020 Ranger
Emergency Management
I have the same issue on cold days and only for a few minutes until the plastic warms up. Out of curiosity, how many of you have Lariats? Or the upfitter switches? My sound is definitely coming from where the defrost vent meets the dash and everything feels tight and in place; just wondering if there's differences in the dash cover that might explain why some of us have this and others don't.
halligan1201
Byron, IL
2020 Ranger
I had this one; hunted for days and even with others this riding in the truck we didn't figure it out. I posted it here and in like ten minutes three others commented to check for the sunglasses lol.
