Curt Receiver Hitch
Neil S
Neil
TN
2019 Ranger Lariat FX
Just an update on the Curt hitch. My local custom shop installed my hitch today without any issues. Hitch was $185 plus $30 instal. It’s a real straight forward instal but my days of laying under a truck in wet weather breaking loose bolts torqued to 196ft-lb are long gone.
This installer had 3 of these hitches delivered yesterday, with 10 more on order but, the warehouse didn’t have any more. Curt is shipping but they are still scarce.
RIRed
Rhode Island
Ford
Just got mine yesterday from autoaccessoriesgarage.com. Was $103 but went up to $112 and free shipping. Easy install, just took me 20 minutes today.
RangerKody
Kody
Orlando, FL
Are y’all ordering the wiring harness from Ford still?
OC4095
2019 Ford Ranger XL
Factory Automation Engineer, Auto School Grad, Car Audio Tech
i contacted them a few weeks ago and they they said "check back later". Great news!
Washashore
JM
Cape Cod, MA
2019 SCab Lariat 4x4
I installed the Curt hitch last week and found a couple of errors in the instructions.
- The socket size required for the M16 bumper bolts is 21 mm , not the 24 mm listed on the sheet
- The torqued value is 146 Ft lbs (195 nm) not 195 Ft lbs.
If you run a few 1/2 bolts and washers in the bumper tabs just outboard of the bumper bolts, C clamps are not needed.
Its also a good idea to blue Loctite the 4 bumper bolts, as they were threadlocked from the factory.
I balanced the hitch on 2 jack stands and was able to install in my driveway in about 30 mins. The Curt hitch has enough clearance under the bumper that the 4 pin connector does not need to be relocated.
FYI it looks like the Drawtite /Hidden Hitch will be available on 4/25 ..
https://www.etrailer.com/Trailer-Hitch/Ford/Ranger/2019/76275.html?vehicleID=201990035
RIRed
Rhode Island
Ford
Looks like the spare tire has to be lowered to install the Drawtite/Hidden Hitch. The Curt hitch just clears the spare when installing.
EcoRanger
Doc
West By God Virginia
2019 Ranger XLT 301A SuperCrew 4X4 2015 Ecoboost Mustang 50 Year Appereance Package convertible
On Amazon Curt 13417 $138.76
YouknowwhatImean
Zack Mayo
Kalifornia, USA
'19 XLT Ranger; '17 6spd WRX
Got the Curt for $130 w tax. Yup to all this. Installed it last night doing the above. Using the 1/2 bolts to hold the bumper in place instead of clamps is the better approach. The hardest part was torquing the bolts back to 150 Ft lbs.
So, if I got this straight, that's all i need if I don't plan on towing RVs? We all have the 4pin under the bumper and that's for brake and signal lights?
t4thfavor
Chance
Some places (kalifornia) also have a brake requirement for anything over a certain weight (1500# sometimes). I suggest checking local laws.
Washashore
JM
Cape Cod, MA
If you are towing a boat, the 4 pin connector should be fine as surge brakes are typically used (which don’t require a brake controller) if auxiliary brakes are needed / required by law...
YouknowwhatImean
Zack Mayo
Kalifornia, USA
"If you run a few 1/2 bolts and washers in the bumper tabs just outboard of..."
Know what those tabs are for -- seems to be missing bolts? I just left the 1/2 bolts on as an added measure.
EcoRanger
Doc
Good info guys I hope to be ordering mine soon
Washashore
JM
Cape Cod, MA
My guess would be that they are locating holes for the factory to align the bumper to the frame.. Maybe a member with ties to the assembly plant can confirm (or correct me ! )
ed1946
elmer
garrison, ky
2015 taurus
Thats what I did, worked great.
EcoRanger
Doc
Had it for two weeks and finally got to install it electric impact and blue lock tight.
