CENTER JACK POINTS
seanellaz
Sean
Tucson, AZ
Healthcare
I could find ZERO Posts about where to locate a hydraulic floor jack to lift the front and rear of the vehicle before placing it on jack stands. Sorry if there is one already. Here is where I successfully lifted the vehicle using a hydraulic jack. Yes I have read that these are not sanctioned points and could break the truck. My truck did not break, nothing bent. I lifted up and down VERY SLOWLY.
AverageWhiteGuy
Mars
2020 Ford Ranger
Professional Procastinator
Nice picture of the front, where's the rear picture? That piece of wood looks like toast! :O
ryyck
Charlotte NC
Will the diff housing crack being on a jack stand? Seems Ford should put "feet" on the frame for jack placements. I'm about to rotate the tires...
seanellaz
Sean
Tucson, AZ
Healthcare
Ima dork and did not keep a pick of the rear jack point in the diff. Also, I cried when I knew I had lost that 6" piece of 2x4. It will never be part of a mansion now. It will, alas, just add a bit of heat to our home in the winter.
port43
Detroit Suburb
childrescuecoalition.org
Secret agent, man
I have never trusted any center point to lift a vehicle and think it's worth the extra time/effort to just lift from the frame. It's not worth getting pinned underneath when you left your phone on the work bench.
seanellaz
Sean
Tucson, AZ
Healthcare
You are correct, sketchy is my forte. The bikes are to camouflaged the work in progress from snoopy HOA bores. 4 stands as needed to remove all wheels to add the 1.25" Rugged Ridge Wheel Spacers to accommodate the 295/70 R17 Toyo open Coutry R/T Tires after the BDS 3.5" coil over lift w/ UCA's was added
seanellaz
Sean
Tucson, AZ
Healthcare
Zero crack or axle sag using the diff as lift point for jack. I lifted gently w/ empty truck and let the axle down onto jack stands b4 taking off the wheels. Yes it would be nice if trucks were built for people w/o fancy 4point lifts to work on, but then, shops would lose out on the $.
seanellaz
Sean
Tucson, AZ
Healthcare
I would love to lift from the 4 corners of the frame, but alas do not have the $thousand or space for such a sweet lifting system
port43
Detroit Suburb
Secret agent, man
OregonRangerTremor
Craig
2021 Ranger Tremor/2022 Bronco/2006 ChargerDaytona
Retired LEO/Dog Trainer
Resurrect an older post. My 2021 Owner's Manual shows rear lift points on the axels and the front points appear to be on the frame rearward of the front tires. As pointed out by the black squares and arrows in the original post. As stated in the manual, any other place could cause damage. As others posted: I am not sure that front cross member should be used and the differential (while done on older vehicles) is a big NO. I have seen photos of differentials with the jack severely cracking the housing. Opinions/corrections....of course.
Cabose-1
Eli
Student
Well, even working in a mechanic garage no one ever had issues lifting vehicles from the diff, or sub frames for the engine. Even placed the axle housings on jack stands. But if you want all four tires off the ground, lift from one side using the frame. If the jack cant reach use wood under the jack. Place on jack stands then lift the other side. If your rotating tires do one side at a time, or if you want all four off the ground to take off tires, then just raise it high enoung to take off the tires. Ill send pics tomorrow if that will help. And the wood on the subframe never hurts.
Craig, I bought a good bottle jack the only one I could find that was made in the USA. Then I bought this Safe Jack kit which goes onto the bottle jack making it safe to lift from several different points under the truck. They have all different height extensions but I found this set works good. Now you're on flat even ground and not worrying about the jack kicking out from underneath you. Of course always use jack stands along with this.
https://safejacks.com/products/3-piece-starter-kit
This was the bottle jack I bought but any one will work with the Safe Jack kit. It's pricey but I wanted something made in the USA and they have excellent reviews.
https://www.gustininc.com/us-jack-d-51123-5-ton-bottle-jack./
JACKSMYDOG
Jay
Ontario
2020 Ranger Lariat FX4 Black
The primary cause of jacking failures is because the load center moves with the pivoting vehicle, but the jack base stays put. This creates allot of instability and lateral force. Safest jacking practice suggests a wheeled jack, oriented perpendicular to the pivot line. When the vehicle is lifted the jack is drawn deeper under the vehicle, and stays below the load. If the load stays centered over the jack, it is very difficult to knock it off or topple the jack.
OregonRangerTremor
Craig
Thanks for those links. I have a large bottle jack....adding those attachments I could see would be very helpful. I am more concerned about taking the truck to any shop for service.....and they don't know where to lift from. Seems like so many "shops" want to lift from the differential.
