- Banned
- #151
I used a short step stool to reach the 8mm mounting bolt and two hose clamps. I used 6” slip joint pliers to remove the hose clamps. They had better grip than needle nose pliers. The two hoses connect to tubing near the part. Very easy to see once the part is unbolted.Having the same issue. Ordered the part LB5Z-9J433-B as everyone else. Anybody have any tips on replacing it? I took a quick look under the hood. I see the part, but I don't see where the hoses lead to/how and what they're connected to. Can they be removed with one hand or will i need to reach in with both? I'm not very tall, so a little worried about reaching back and under. Just want to be prepared for when the part comes
Just an update: It appears this also fixed my bucking issue. I had to climb up into the engine bay on my knees to reach/see where the hose clamps are. Truck also feels like it has more pep. Didnt realize how sluggish it was.Having the same issue. Ordered the part LB5Z-9J433-B as everyone else. Anybody have any tips on replacing it? I took a quick look under the hood. I see the part, but I don't see where the hoses lead to/how and what they're connected to. Can they be removed with one hand or will i need to reach in with both? I'm not very tall, so a little worried about reaching back and under. Just want to be prepared for when the part comes
That's my plan.I think I am going to proactively replace this after I get enough miles on it.
You're probably american, but for my canadian brothers on here, I get my parts from https://www.eastgatefordpartscanada.ca/Where did you guys order your replacement parts ?
Is this the part that everyone is talking about and its fixing the buking issue? Attached is from LevittownFordParts.com, Benny is in the forum here. I think I'm ordering one cause I feel a bit of bucking .Where did you guys order your replacement parts ?
+1 That’s as cheap as you’ll find it.Is this the part that everyone is talking about and its fixing the buking issue? Attached is from LevittownFordParts.com, Benny is in the forum here. I think I'm ordering one cause I feel a bit of bucking .
Is there another cause of bucking?How the hell is everyone getting this off?????
