Bilstein 4600 shock upgrade worth it ?
Mike Shaw
Northeast
2022 Ranger 4x4 xlt
Na
Have a 22 Ranger 4x4 towing a 5000# 20’ travel trailer .
if I up grade the front struts and rear shocks to Bilstein 4600 , is there a noticeable difference . Or am I just feeding the cash cow ?
want to retain stock height
I can tell you now you are definitely going to feel a difference. The 4600 in the 5600 series are supposed to have the same valving overall. I have also had a 2016 frontier that had factory 4600 series shocks and I could tell you it was a nice ride in general. To some it might be a little stiff but if they're tuned correctly for the vehicle they will provide a great ride. They should also help with the overall control while towing
Mike Shaw
Northeast
2022 Ranger 4x4 xlt
Na
Truck has a little movement when towing
Mike Shaw
Northeast
2022 Ranger 4x4 xlt
Na
Do I need both front and back or can i just go with the rears only
If on a budget you can do the tears for now, but I highly suggest doing front and rear at the same time so they work together.
LoneRNGR
Lubbock, Texas
2020 Ford Ranger XLT
Systems Engineer
Doing the rears will have the most noticeable effect. The shocks probably aren't going to affect your towing or your ride height as long as you don't make any other "height" adjustments to the suspension.
jflogerzi
Moreno Valley, CA
Rears are cheap and very easy to install. Might be all that you need. Fronts are bit more work and will cost 4-500$ for a shop just to install.
Reactions: EJH
Apparently you have not towed a trailer with the same vehicle and different shocks. Two different shocks for the same vehicle will feel different enough that you can feel. With the way the OEM shocks are with the Ranger I can promise it makes a huge difference simply by having shocks that do way better at controlling the load
Reactions: EJH
MXGOLF
Sales / Photographer
Bilstein's are the way to go. I have both the front and back 5100's. $1000 for the shocks and install by Les Schwab Tires. That was almost 3 years ago now it's probably more. I tow a tent trailer and don't even know it's back there. Just my 2 cents worth.
jflogerzi
Moreno Valley, CA
Just trying to save the OP $$$. Best bang for your buck is in the rear IMO. I would start their and move to the fronts if its still an issue.
Understanding the way you're thinking I can promise you the vehicle still going to do best when you have the fronts and rear shocks matched regardless of brand
Andrew27
Andrew
Missouri
23 Ford Ranger, 95 Ford Explorer, 98 Ford Ranger
Auto Technician
Short answer…yes! My first highway trip with my 23 FX4 just about made me sick from the bobbing up and down, like the shocks were blown…with 500 miles. I installed the 4600s on all four corners, and it feels like a night and day difference! It is more “firm” I would say around town, but on the highway it is so much more stable and controlled.
