Biggest tires, no lift?
QCRanger48
Connor
Queen Creek, az
I just put Bilstein 5100's on that are more of a leveling kit than a lift. Brought the front up 2.5". I currently have the stock 265/60/18 on my 2019 and am thinking about going to a 275/70/17. Would that work with what I've got going on? Willing to cut crash bars and have some offset if necessary.
JimboAnz
Charlotte
2020 - Sold
It’s almost time for my stock tires to be replaced on my 2020 XLT FX4. I have the 18 inch black OEM wheels. No lift no level. Stock tires are 265/60/18. Which is a 30.5 inch diameter tire Hoping to stuff, 265/70/18 falken wild peak‘s in there which say they are 32.6 inch diameter. I know I would be safe with a 265/65/18, which is a 31.5 inch diameter tire, but want to go as big as I can without any modifications. I have read through all the threads and I feel I have the right information. I just need some reassurance. Thanks y’all.
~Jimbo
OrangeStreak
New Mexico
~Jimbo
Jimbo,
My research showed that 265/70/17 or 265/75/16 is the biggest you can go on stock suspension. The link below should give you the maximum size for your 18's. I have stock suspension with 265/70/17's and they work great...no rubbing. I got under the truck and double checked for rubbing...none!
Largest Tires on a Ford Ranger (Biggest Tires, No lift) – 4WheelDriveGuide
NakeyJakey
Jacob
2021 Ford Ranger Lariat
Disabled
Too early to say accurately, just installed them on Thursday. I will update you after i have a fair comparison. The tread of these tires is only 7.5 inches wide, compared to 8.5 for a bfg or 8 inches on the new bridgestone destination XT. Also this particular duratrac is eurometric standard load, rather than being an LT metric tire. Eurometric duratracs come with a 50k mileage warranty.
Just going through this thread and was wondering if you ever figured the gas mileage difference with the 255/75r17
Doc
Doc
Live oak fla
Installed some 265-70r17 Falken Wildpeak A/T3W load range E on my Fx4. No lift or crashbar modification - all stock. Very happy and no issues with rubbing (although its close in the front on full inside lock)
p.s. ignore my dirty truck!
Looks Nice ! Are those stock steel rims ?
I have no “lift”
285/65/18 on 18x9 0 offset.
yes they will rub, yes I removed, bent, and cut things.
Looking pretty sick Mike. We’re going to have to start a new thread, “Biggest Tires, Negative Lift””
