Belt Tensioner SNAPPED OFF
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
dondonbabyraptor
Brandon
San Diego
IdahoRanger
Idaho
RETIRED
Hey Steve! Good seeing you. I noticed a few only 2020’s it’s happening on too I believe.
Situation is quite sad. Just getting ready to pay up to get it fixed
Did it damage any wiring or fan when the belt came off?
dondonbabyraptor
Brandon
San Diego
Not that I can tell. But I found the piece while looking around. Although my charging system service light came on, and water coolant light. Not sure how cars work enough to know if that’s related to the tensioner/belt system or if it broke something else.
You have to remember that on a majority of vehicles out there, the water pump, cooling fan and alternator are usually driven off the serpentine belt. If you loose the belt or tensioner, you can loose those things easily causing a charging system fault and an engine overheat.
dondonbabyraptor
Brandon
San Diego
Ahh okay
That makes sense. Figured the belt was tied to those systems. Appreciate you chiming in with the knowledge Frenchy! Good to see you too.
Here
XLT
Hey Brandon,
That really sucks - as Steve said, this has happened to others. I take it you’re out of warranty. :(
So, what major part of the engine is that supposed to be attached to? Water pump? Timing belt cover? Something else? I’d go look at my truck but I’m glued to a beach chair. 😝
Also………
IdahoRanger
Idaho
RETIRED
Hey Brandon,
Also………
Seems to be happening on the covid trucks.
Living The Dream
I don't think there has been a single instance of this happening on a model year other than 2020.
IdahoRanger
Idaho
RETIRED
Maybe the tariffs at the time caused Ford or its suppliers to change aluminum providers and there was a QC issue? Do you know if these are cast or cold-forged? Maybe some other process?
Me, not a clue.:crazy:
Good thing the Tariffs were not the cause then as the Tariffs were nowhere near as high then.
