Average Oil Change Price
wanted33
Down south in Dixie
Mustang GT, Jeep Wrangler
Old used up LEO
I did the Works at the dealer Saturday for 70’ish. Plus free coffee and donuts! :clap:
That's the ticket Joe. I just give the keys to the service writer, grab a cup of coffee and walk the lot to look at the new trucks (what there is these days). :)
BTW, I remember in the not to distant past that 70 bucks "Works Package" was $39.95. Damnit......:facepalm:
EJH
Ed
Subarus, 2021 Ranger
Two different dealers in Oregon have been from $70-100 for "The Works" which is a waste on me since I don't need tires rotated. My tires are rotated when I swap the winter wheels on/off in fall and spring. FWIW, Subaru has gone up to about $80 for a full synthetic oil change also (but I almost always do those myself).
So I'd say anything up to $100 is the going rate, for better/worse ;)
Stevedbvik1
2022 Ranger Tremor XLT
FYI the “Works” package does not include any diff, tcase or trans fluid level checks.
Radioman
Kent
Roseville, CA
6 qt Mobil One (plus 1 qt left over) = $27 + Motorcraft OEM filter $6 = $33...
Well Sid, I pay a bit more at Walmart for one 5 quart and 1 single quart here in California, $38.17 including tax. I have several filters that I got through Ford Pass points. I also used about $1 of windshield washer fluid. I have been averaging about 2,000 miles per year so 1 oil change a year. I rotate the tires at 5k miles and inspect the brakes at that time. When I change the oil, I take the time to look over the underneath the truck and under the hood. Doing my own maintenance ensures it is done correctly and torques are correct. I worry that at 77 years old, there will come a day that I will be unable to crawl underneath the vehicles and I will have to rely on others to service my vehicles.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
FWIW, the places charging $100 don't do those either. Nor do they rotate tires and check brake pads.
mokupilot
The Aloha State ?
22 DeeZee Lariat Tremor, 09 Escape Limited
Heavy aluminum tube logistics and transportation ✈
I used to just take my cars in to have the oil changed & tires rotated because the price was low enough that I didn’t want to do it. Now that prices are terrible all over I’m back to doing it myself. So, here’s my stupid question - Are you supposed to reprogram the TPMS after you rotate the tires?
EJH
Ed
Not needed. There is a relearn procedure, but our trucks (at least mine) will relearn what is in each corner after a few miles. I swap my A/T and winter wheels myself and have never needed to do the TPMS relearn. I have verified the truck knows which TPMS is on which corner by randomly lowing pressure in one tire. The truck always has the one I aired down in the correct position.
Radioman
Kent
Roseville, CA
As Ed stated, no action is required after rotating your tires, at least in my experience.
moorejl57
Jamie
Corvallis Oregon
2021 Ranger Lariat FX4, 501A, fully damped
I do my own changes for about $30-35 using either full synthetic or synthetic blend. I change every 3000 miles, so the quality of the oil is not quite as important. I have noticed the synthetic blend was a bit more runny even though it was 5W-30 and API SP rated. I also noticed I got slightly better mileage with the blend. Last 200 mile round trip I averaged 26.5 mpg vs the 24.5 mpg I normally get.
