Jamie Jack
- First Name
- Jamie
- Joined
- Feb 6, 2024
- Threads
- 1
- Messages
- 74
- Reaction score
- 214
- Location
- Kelowna, British Columbia
- Vehicle(s)
- 2021 Ranger XLT
- Occupation
- Retired
Drive in S rather than D.
yee, its in:If I had known that I could disable it through Forscan, I would have gotten it as soon as I got the truck in July 2023 instead of this past march
As much fun as these trucks are in S mode, I am on my third transmission at 113k miles and don't want to go through two tanks of gas a week.Drive in S rather than D.
Me as well. For those who have a pc laptop and access to amazone to get the scan tool, itll cost less than $100 total and you wont ever have to look at the button againyee, its in:
BdyCM(BCM)
BMS/Auto stop start system - Select 0 - Off(permanently).
you can always go back to it and select 1-on(Default)
Its what I did.
This.I'd rather just plug in a phone charger or a night light. Why mess with the battery system?
While you in there set your battery state of charge (SOC) up to 95% - 100%. It's set at 70% for XL and XLT trims, and 75% for Lariets, If you really want to extend the life of your battery.No that the EPA no longer mandates this stupid auto stop/start system, is there new FORScan or Ford software update to turn it off? I see the 2027 F-150 will NOT have it installed!
How does one change this setting? My battery is a year old but would like it to last as long as possibleWhile you in there set your battery state of charge (SOC) up to 95% - 100%. It's set at 70% for XL and XLT trims, and 75% for Lariets, If you really want to extend the life of your battery.
I have mine set at 100% and I'm still on my original battery in my 2020 Ranger. Of course I made these changes (plus adding a BatteryMinder Onboard Desulfator) within a year of purchase after the first (and only) low battery warning.
70% - 75% is really unacceptable for battery health, causing rapid battery sulfation and higher internal battery resistance, i.e, failure....
It's in the BCM (Body Control Module). Battery Target State %How does one change this setting? My battery is a year old but would like it to last as long as possible
Oh yeah, i set mine to charge to 95% the same time i set ASS to off with Forscan. So far so good, 4 years and still going. Lets see how long I push this lol.It's in the BCM (Body Control Module). Battery Target State %
Battery system??? It is a simple unplug at the neg Battery terminal. Could not be easier. Make it complicated if you want to.Yeah...someone already brought that up in the beginning of this post. I'm not pushing a button 10 to 15 times a day. I bought a tuner. Got a better driving truck and it deleted the auto start stop.
Are you sure about that? My 2020 has been unplugged for 5 years with no issues.It does more than disabling Auto Start/Stop. Disconnecting it will also disable the Battery Management System that controls battery charging and presumably extends battery life and helps fuel economy.
Yes, I am sure. There are other threads here that discuss it in detail. Its function is to calculate the battery state of charge. One reason is to make sure the battery has enough charge to restart the engine if ASS has stopped it. If there is not enough battery charge, it disables Auto Start Stop. But it also is used to control the charging rate of the battery. When you unplug the BMS, the state of charge can no longer be known.Are you sure about that? My 2020 has been unplugged for 5 years with no issues.
