Are engine enhancing oil additives a gimmick?
HDEO
Kevin
West Marin
Ranger Tremor, M240i
Formulator
Hello,
Can someone with some experience or science knowledge tell me about this product and the claims they make?
https://www.shinearmor.com/collecti...booster-oil-additive-1?variant=29406697685078
Our Performance Booster Oil additive is a cutting-edge, nanoparticle-based solution that works great for gas and diesel engines alike. It boosts the performance and lifetime of any oil-lubricated system under the hood, aside from the air conditioning unit.
Our clients have been stoked about this product because you really can tell the difference in your engine after using it. Our booster oil pumps up your horsepower and extends the durability of your entire engine.
Did we mention it’s eco-friendly? We made sure not to use any harmful chemicals that would damage your vehicle or the environment, so you can rest easy knowing your car is about to get a jump start to its energy.
Use Performance Booster Oil Additive after getting a fresh oil change, or use it on the oil that you have now. Doesn’t matter if you use conventional or synthetic oil blends either; we got you covered.
Our advanced formula works its way through your engine system’s microscopic crevices to reduce the wear and tear the years have put on it. It can even reverse existing engine wear.
We’re so proud of this product and know it’s going to change the way you drive that we offer a 100% money-back guarantee. If you aren’t satisfied with the boost in performance, just send it back and get a full refund.
  • Safe & easy to use
  • Increase Horsepower and Torque
  • Works in almost every type of vehicle
  • Quieter Engine, Reducing Noise and Vibration
  • Stops Cold Start Problems (Tested to -40 Deg.)*
    Increase Fuel Economy up to 4.2%*
It all sounds oddly too good to be true but I really don't know much about cars and the science behind things nor how far technology has come along. Also would it be safe in our engines you think?
Warm regards,
Brandon
I spent 20+years formulating engine oil additive systems for diesel trucks. I would not recommend use of any aftermarket oil additives. They will cause issues and likely just end up in the oil filter. Save your money and buy a good oil.
dtech
colorado
Everyone knows or should know STP was and continues to be the racer's edge, I loved seeing those commercials decades back with Andy Granatelli seemingly shoe horned into his trench coat - speaking of which I visited the Smithsonian and Andy's trench coat resides in perpetuity in the museum of natural history. Please honor Andy's legacy and if you must use an additive make it the racer's edge.
https://www.hemmings.com/stories/2013/12/31/andy-granatelli-mister-500-dead-at-90
https://www.si.edu/object/trench-coat-worn-andy-granatelli-wore-stp-television-commercials:nmah_1849103
Radioman
Kent
Roseville, CA
Hello,
Warm regards,
Brandon
To answer your question: YES
Also(from the Owner's Manual)(I added the bold font):
We recommend Motorcraft® motor oil for
your vehicle. If Motorcraft® oil is not
available, use motor oils of the
recommended viscosity grade that meet
API SN PLUS requirements and display the
API Certification Mark for gasoline engines.
Do not use supplemental engine oil
additives because they are unnecessary
and could lead to engine damage that your
vehicle warranty does not cover.
Back in the day, before Andy G., Richard Petty pushed STP...and we all went for it.
It was the 60's and engine tolerance's were measured in inches back then, not micron's like today.
STP was a catch-all to thicken up anything in your engine, rear axle, or manual tranny.
Any noise in any of them you just poured 2-3 cans of that magic elixer....it was a sure fire cure. and it worked, until the noise came back and we used more of it.
After all, would Richard Petty lie to us ?
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Funny thing, Andy Granatelli was retired and lived in my area. He would be driven around local car shows in a golf cart. He was a very large man. He has since passed away.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Modern oils are good enough that they don't need additives.
Back in the day STP could be somewhat helpful but oils weren't as good then. It was only helpful if you used it all the time, not after you already had issues.
The only additive anyone really needs is a zinc additive IF you are driving an older vehicle with flat tappet lifters.
Years ago I got hip to an internal engine cleaner on BITOG called Auto-RX which I have used on used vehicles I've bought and it does seem to work as advertised.
Living The Dream
A sure fire way to tell if it's snake oil is to see if it recommends shaking it up before adding.
If it settles sitting in the bottle on the shelf, it's going to settle in your oil pan too.
With the tolerances being so tight in modern engines, I don't want any fairy dust floating around in there that could cause blockages.
JustSteve
2019 Ranger XLT
Not a chemical guy but it sounds to good to be true becaise it is. I got an good laugh out of the reverses existing engine wear. Remember STP it made a lot of the same claims in its day. Nothing more than a viscosity increaser.
Just use a good full synthetic oil of the recommended grade and change it regularly. Forget about the additives with their wild claims and keep your warranty intact.
Does that mean adding STP could help with the damage oil dilution is doing by increasing viscosity?
Langwilliams
Langley
Lorain, Ohio
My younger brother used to buy Lucas oil stabilizer for his cars. He was an amateur drag racer an believed "if they use it in those big money engines it must work an not do any harm". He didn't want to hear they got paid to use it.
OrangeStreak
New Mexico
Most people want to get protection and as much longivity out of their vehicles as possible. My view is not scientific but practical. I don't feel that it is a good idea to add anything to the oil. Quality oil is designed for modern vehicles to give the maxmum lubrication and protection as long as it is changed at substancial intervals. See Edmunds video below which shows how to choose the right oil and also mentions needed additives that are already included in oil that is retailed. I believe that Ford's advice about additives on p. 263 of the owners manual is correct and the safest route...
dondonbabyraptor
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
Again, thank you all for the different insights. Makes a lot of sense it is a gimmick. Now understanding that modern day oils are quite efficient and should just keep to that.
dtech
colorado
yes but did he continue to wear a trench coat
