If you are Modding up the 2.3 engine... THIS might be the oil to use.
SemperVee
Dar
Olympia WA
2022 F150 LARIAT. 2019 Ranger XLT Traded in.
Took the 2020 HPP Mustang with 2.3 + 30 more HP into it's first oil change @ 2000 miles. Expecting to see it had ranger 5-30 oil in it only to find out it was 5-50 Motorcraft Synthetic for High Horse power and track use motor as this one is... So if modding your engine this might be the oil to use.
Crown Forklift Technician
Last i checked Ford recommends 5w30 so I will keep using 5w30. If you are going far out of manufacturers specifications and building a race vehicle then it will be a different story. I'm sure @P. A. Schilke can elaborate more on this.
Hi Chris,
I can add that the oil used for or durability testing is the oil listed in the owner's manual. If there is an extreme duty oil listed, it will also have been tested, but likely mostly a dyno simulation of the extreme duty events. Ford does recommend a different oil for cold climate, 0W-30 which has a different specification I recommend like you that you use the oil specified that meets the Ford specs or exceeds them. Not sure what is in the Mustang owner's manual, but the motor is in an entirely different animal than Ranger.
The owner's manual also has this:
If you do not use oil and fluid that meets
the defined specification and viscosity
grade, it could result in:
• Component damage not covered by
the vehicle warranty.
• Longer engine cranking periods.
• Increased emission levels.
• Reduced engine performance.
• Reduced fuel economy.
• Reduced brake performance.
