Another new wheel and tire thread...
DHMag
Dale
San Antonio, TX
Today, I finally got new tires, after 6+ months of financial setbacks. The OEM Bridgestones had 44,010 miles on them and were nearly to the wear indicators.
I bought RTX Offroad Slate wheels, 17x8 +25 back in October. I originally wanted to get some powdercoat done on them but the price of out of my ballpark for 2 color powdercoat, so I may end up painting them. I am so not a fan of all black wheels.
Tires are Firestone Detination LE3 in 255/65/17. Eibach struts installed up front set at 3/4". I initially installed them at stock height, but because the strut housing is taller, I was basically riding on the rebound bumper. To be honest, I can't tell the difference between the Eibach and stock struts.
Anyway, onto the pics !
Sparky2
Kansas
Retired electrician
Great looking wheels, can’t say about the tyres but I’m sure you’ll let us know how they handle.
Looking beyond the truck, your garage has a similar look as mine did before I retired from 40 years as a self employed electrical contractor.
Assuming this is a 2WD truck why didnt you go ahead and get a bigger tire to fill the wheel well a little bit? Its already confirmed that 265/70-17 will fit on these trucks without modifications and I'm sure the Destination LE3 is made in that size as well
Being a Firestone guy i can already tell you the tires do well for a street tire. I habe a set of 265/75-15's on my 1994 F150. So far good traction in dry and wet. As for mileage, it will depend on many factors. That said, dont expect to go OffRoad with them
DHMag
DHMag
Dale
San Antonio, TX
Several reasons:
Unsprung weight
Didn't want to change tire circumference
Edit: If I didn't care about fuel mileage, I would have gone bigger. But I have never found a clear answer that 265/70 would fit on a stock 2wd with +25 wheels.
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
Hey Dale!
The new wheels look amazing basically copied after the infamous Enkei RPF1 design. Love it. Was it just the front you did and not the rear? I find the rear shocks help the most. For daily driving, I get less body sway when switching lanes at high speeds. Also, another way to test if you feel a difference is driving on bumpy roads that you normally do and also when you go over speed bumps. See if you see a difference there :)
Warm regards,
Brandon
dondonbabyraptor
Brandon
San Diego
Several reasons:
Unsprung weight
Unsprung weight low as possible is KING for MPG and performance.
Several reasons:
Unsprung weight
Did a quick check since I was curious about weight. From what you have vs a 265/70-17 on the same tire you only add 3 lbs per tire going from 34 LBS to 37 lbs. That said you should be able to get good MPG with a 32 if that is a concern. I have 265/70-17 Bridgestone Dueler REVO 3's(P Rated) and they weighed in at 40 LBS a tire. With the Old Man EMU lift and being a 4WD truck I was able to see mid 20's most of the time and had times I was high 20's seeing close to 30. Being a 2WD you should be fine.
DHMag
DHMag
Dale
San Antonio, TX
Hey Dale!
Warm regards,
Brandon
Hey Brandon,
I have not installed the rear Eibach shocks yet but will be doing it sometime later this week. I basically installed the fronts twice so I need some time to recoup lol. Old man problems...
DHMag
DHMag
Dale
San Antonio, TX
I'm happy with what I got, but thanks for the feedback.
dondonbabyraptor
Brandon
San Diego
Hey Brandon,
I think there will be more noticeable difference once the rears are on. It's the butt body sway that was a bit terrible.
Langwilliams
Langley
Lorain, Ohio
nice. You got twice as many miles of the stock Bridgestones than me. I ditched them at 24K an was close to the wear indicators. Maybe it's the tune spinning the tires!
RANGER_MARC
MARC
Delaware USA
FORD RANGER LARIAT 2019
TEACH
Hey, those black wheels look great to me as is--like the rest of the truck...
