Am I the only one that can't get all the oil out during an oil change?
WoodrowX
Utah
2019 Ranger XLT
I've done 3 oil changes myself on the Ranger and each time I get out about 5 1/2 quarts of oil. I drain the pan, then move to the filter. This last time I removed the oil cap and dip stick before draining thinking that I may have a vacuum of some sort keeping oil from draining, but it didn't seem to make a difference.
How much oil are you all draining when you do your oil changes?
MINI Ranger
Gene
2019 Ranger Lariat FX4, 2014 MINI Cooper S Clubman
ASE Master Technician, MINI Technician, Retired
I haven't actually changed my oil on the Ranger as it came with "free" oil changes, but apparently the dealers have trouble with this too as mine is always overfilled after an oil change.
It's possible that the oil is not drained completely due to not removing or loosening the oil filter before draining the pan. This happens on most BMW/MINI vehicles.
WoodrowX
Utah
2019 Ranger XLT
Thank you. This makes sense. The next time I am planning on ensuring my oil filter is removed before draining the pan.
I_smell_like_diesel
Western Maine
2019 Ford Ranger FX4 Lariat
Self Employed
When I do oil changes, on my personal vehicles, I drop the oil first, re-install the drain plug loosely, remove the oil filter, let the oil drain oil out of the oil filter adaptor, and then install the new oil filter. By the time you go through all that, there's another quarter to half quart of oil in the pan. Pull the drain plug again to drain the rest of the old oil. Then follow through with finishing the oil change.
As long as you run the correct spec oil, run quality filters, and change it within reasonable service intervals..... you should not have to worry about sludge.
Ive never had the issue with my truck. I also just put 6 qts in it instead of the 6.2 qts. The level is about right of not just below the top.
Just a thought but maybe this is the "quote on quote" oil dilution people are heavily concerned with?
pbethel
Patrick
kingman az
I have been changing my own oil for nearly half a century and only once have I not overfilled slightly if using the published amount.
When I had my boat engine oil pan off for over a week while prepping and painting a new one, the oil drained completely enough that 6 quarts put it exactly to the full line.
It was still occasionally dripping as the new pan was installed
Try it like this...
Turn vehicle upside down, run engine to heat oil up, and open oil fill cap to let it drain.
Turn vehicle right side up, re-fill with fresh oil, re install fill cap, and,
Wallah...your done !
tit64
Terry
Canada
Ranger 2019 Lariat
CTR
Hello;
Will try this method next time I flush my truc .
Thanks guys .
Dgc333
21 Ranger Lariat
I always remove the filter first. There is an anti drain back valve in the filter that keeps all the oil in the oil passages from draining back into the pan. Removing the filter allows this oil to drain.
I did the first oil change on mine about 1500 miles ago and put 6.2 quarts in. That filled it to the mid point between the top of the hash marks and the max fill hole.
midwayfordranger2021
Keatchie LA
2021 Ford Ranger 1990 Ford Country Squire
Truck Driver
That's a good point about removing the filter first. I 've always done it the other way around, but it does have that drainback valve in it, so some oil may well be remaining in the engine. But 6.2 approx. is usually what I put back in. That gets it to the top of the crosshatch usually.
