- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,578
- Reaction score
- 8,740
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
- Thread starter
- #91
I edited my above post to include this:
And I need some assistance from @Big Blue and or @jdjeff or anybody else that has the Morimoto's or querulant that has the startup animation and has issues with it working properly.
What this (Test) does - (Test Only) is we are taking to switched power source and simply touching the positive side of the battery (temporally By-Passing) a Tapped Power Source, I want to know the (Operational Outcomes) with the Headlight Position in Headlights (On) before the tapped power is introduced.
EDIT: I need to edit something here as I am still diving into this a little deeper.
I need to correct something here - The BCM Bulb check is NOT killing the power and causing the Start Up Sequence to (Abort) - It's not the BCM specifically but it's the Bulb Check conflicting with the Logic Controller in the Morimoto's and the Logic Controller (itself) is aborting the startup sequence from the (momentary pulse)
I think I have a solution for a fix and it's a simple solution - but i need some help from @Big Blue
and another test - he performed.
@Big Blue , when you performed the operational test of the (Start-Up) animation
and you performed the test:
Key-OFF and Headlight Switch - AUTO - Start Up Sequence Worked - DRL Illum Bright
Key -OFF and Headlight Switch -PARK - Start Up Sequence Worked - Park Illum Dim
I need to know the outcomes - with Key-OFF and the Following
Headlight Switch - OFF
Headlight Switch - Headlight (ON) - Low Beams (On) and (High Beams (On)
I want the Headlights to be (ON) and stable before you touch the battery with the Tapped Power.
This is an important factor - and does the startup sequence - start or abort midway or complete.
The test outcomes will verify if my solution works as a fix to get the animation to work flawlessly every time.
