Busted
- First Name
- Robert
- Joined
- Oct 26, 2025
- Threads
- 2
- Messages
- 13
- Reaction score
- 70
- Location
- North Carolina
- Vehicle(s)
- 2020 Ford Ranger Lariat 4x4
- Occupation
- Injection Mold Setter
- Thread starter
- #1
Swapped out the factory grill today. One issue is the harness that comes with it appears to be for AU Ranger I think. Does anyone happen to know if you can de-pin the factory style 8-pin headlight connectors? The female side looks doable but not sure about the male side plug. I see SPV has a headlight harness for something else and was thinking if I could reposition that tapped pin to the DRL signal wire on pin 6, I could just make my own harness to connect the grill lights. The grill uses a 3 pin connector.
My plan was get the SPV harness, reposition the tapped wire from pin 5 to the DRL signal (pin 6), run an add-a-fuse to an available spot in the fuse box, run a ground to chassis or something, use a weatherpack 3 pin plug to keep it all nice and tidy.
Any tips or advice is welcomed, don't really mess with wiring much. I really don't want to cut into the factory harness for anything.
