- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,629
- Reaction score
- 8,832
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
- Thread starter
- #16
So, the question is - since some are having issues, your changes were already programmed into the BCM @ install, for those that did not make any changes and just simply (Installed & DE-Selected) the IPC Menu for (Daytime Lights - DRL's)The Morimotos/OLMs work the same way. The Forscan changes I made were .y own choice and were done long before I installed my OLM lights. They were not necessary for the install. The only change needed would have been turning off the DRLs in the IPC menus.
What is the (They Work Flawlessly) vs (I have Issues) numbers and what specific fussed source is being used for the (Tapped Power)
I (THINK) yours are working without issues as you had already made the changes via Forscan.
Since we know that the Tapped Power source is the issue here, we just need to find the smoking gun (for all) owners of (This is what you need to do, and this (POINT) is the root of the issues some are having.
I need to dig back into the complaints and issues to isolate down the problem location for the Morimoto (Issues)
as since I have learned how the (Start-Up) sequence works (powers) and the Morimoto's do not have a Pin #6 and then factor in what the BCM is trying to do it makes it challenge.
So, @jdjeff - For now, I would reset your As-Builts back to factory settings, and then have you confirm (What Fuse) are you using for the Taped Power source.
Referring to the (Start-Up) sequence not working when the switch is in (Auto) or only the LF headlamp is the only one giving you the (Start-Up) sequence.
With me learning that the (Morimoto's) do not have a Pin #6 on the Component Side then that requires the (Tapped Power) source for the (DRL Operation & Start-Up Sequence)
Until I can find the specific (As-Bult) data file that will provide power to (Pin#6) just like the Tapped Power source, we can get the DRL side of that power to function with using the Forscan changes and setting them up as (Lariat LED's) but that power on Pin #6 is only provided when the DRL's are commanded (ON) - So In (Auto) and out of (Park) and (Daylight) that is the only time pin #6 will have power. (So even wiretapping Pin #6 with the (Lariat LED) settings, the (Start-Up) sequence would not work @ power up.
So, since the Morimoto's do not have a Pin #6, then the added power tap, provides the power source (instead) of the BCM.
The issue I think for the (Start-Up) sequence not working properly is that I had you change the As-Builts and did not know at that time that the Morimoto's did not have a way to tap the BCM power for Pin #6.
I also realized that Pin #6 even if you (Wire Tap) the harness side of pin #6, and made the Forscan Changes to match (Lariat LED) settings, you can possibly make them work correctly except for the (Start-Up) sequence, as it would only work when the BCM commands power to PIN #6 (DRL) Mode
For your other issue - Delay from Headlight to DRL, such as this example:
I park in the garage, when I start the truck my Factory LEDs, trigger on (Headlights) as I am in a darkened garage.
I back out and hit the sunlight (The Lighting Sensor) on the dash, registers the lighting change and then communicates via the data bus, to trigger the Headlights (Off) and DRL's (ON) there is a slight delay in this process, and it falls into (the amount of time) before it will switch, think driving under a bridge or underpass where the sensor momentarily gets shaded, it keeps the DRL's activated unless that shaded source is a longer period (such as driving in a long tunnel) then the Headlights would trigger (On) and the DRL's (OFF)
