Adding the Terrain Management System
Ranger3
Dj
New jersey
2020 Ranger Xlt Sport 4x4
Store Mgr
Forscan is free. You get full trial for 2 months and then for a small fee you can get an extended license. Personally I did the lifetime one because they deserve the support for what they provide. It’s a WIKI group so crowdsourced and not a company. https://forscan.org/home.html
Ok so what do I use to connect to the Ford? My cell?
On the website they recommend an OBD unit that connects to your PC. It is not recommended to use wireless to do these settings. I have both but decided to buy the wired one to play it safe.
Ranger3
Dj
New jersey
Store Mgr
Can u please link me. To yours I would appreciate it
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
I want to do this pretty badly after hearing someone needing it on dunes. A little bit nervous though.
Steve23
Steve23
Stephen
Maryland
Software Engineer
It's a joke to do. Connect OBD2 to your truck, download forscan and enable it (its literally change a single value) and to install the button all you have to do is pop some of the center trim up and swap the button.
MassRanger
Nate
2021 Ranger
Maintenance mechanic
Is it possible to add the terrain management selector on the low model dash?
103
Dustin
2019 Ranger XLT Sport 4x4
It's the basic black and blue screen in the instrument cluster
Your tcase selector looks identical to mine. I installed the TM button version and made it all work through forscan.
MassRanger
Nate
2021 Ranger
Do you have the black and blue instrument cluster?
Superdannyboy
Has anyone added terrain management to a rwd? I'm looking to race my truck on a rally track and would like to keep the rear locker on but would like to use sand mode to keep abs from kicking in when swinging the rear end out in turns.
I can disable abs but then I can't lock the rear and I at least want that for when I take off even if it shuts off at 20mph.
I don't even have the knob for 4lo and 4hi since I'm rwd so I'm wondering if anyone has added TM on a rwd.
I am curious if it can work. First I would check under the center console and look to see if the connector for the 4wd switch is there. If it isnt there then I cant promise if it would work. If it is then get the correct 4wd switch and enable through Forscan and see what happens. Worst case it doesnt work
Superdannyboy
That's true, I'll look tomorrow for the switch to start
