Adding OEM rear axle with elocker
jleds
Jay
Honolulu
2019 Ford Ranger XLT
Hello! Hope you guys are well. Question for y'all. What would I need to replace my current rear axle to one with a elocker? I know I'll need the whole assembly and the switch but I want to make sure what else is needed. Ive been patiently waiting for a torsen diff but so far nothing yet. Thanks in advance for the info!
I am not sure if this has been confirmed yet but I believe those are the only two things you need as long as your truck is a 4 by 4. Looking at my Ranger it has all the wiring with the exception of the sub harness for the rear diff so that would be needed as well. After all those are added and you go into for scan and enable the Locking diff everything should be kosher. I have yet to confirm this myself as I've been spending money on other things
jleds
Jay
Honolulu
Thanks Frenchy! I always look forward to your input on these things.
I wonder what the cost difference would be between a factory swap and adding an air locker?
Close to the same if not a little more for the air locker just for the fact you have to get a compressor, new ring and pinion, ring gear bolt, bearing and shim kit and you have to have hose plumbed to the axle. Just because there is tye option of factory wiring from the diff already I would rather go that route as there would be less chances of hang up.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
OX Locker makes lockers that can be actuated manually (cable), pneumatically, or electrically. Electric lockers and install kits will run you about $1200. Although I'm not sure about availability for Rangers. I agree with Frenchy that an OEM rear axle assembly would be easier. And maybe more cost effective if you could find a used one from a salvage yard.
jleds
Jay
Honolulu
Appreciate the input fellas. Levittown Ford has them listed relatively cheap so I may go that route. Idk if I should go through a dealership or a local shop. Not sure how complex the wiring and software process would be. I would do it myself but the way my bank account is set up, I can't afford to risk it lol.
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
Update us if you find out what pricing is to install from dealer after buying through Levittown
VAMike
2019 Ranger Lariat SuperCab
It would probably be cheaper to trade in the truck and get the one you wanted.
Unfortunately it would not sir. Not as cost effective if you already own a ranger without a locker. That I have already checked on
VAMike
you haven't been reading the threads about making a profit on a trade in?
I have but of you have been making a lot of payments and dont feel like giving up your investment then you would understand what I'm talking about.
