Adding the Terrain Management System
NotBudule
XLT
I would imagine it needs some info from the transfer case telling it all is well and 4wd is a go before the TM kicks in ... May still work though ,. probably make the dash light up in places...
Even if you have wiring for switch, all drive modes except (Normal-2WD) allow selectable modes such as Sand. The system will not activate unless it sees 4WD engaged. So, IDK if some Forscan changes can fake it or not, but an interesting Mod if successful.
Superdannyboy
Yea it doesn't seem worth it. Looks like best bet is to disable abs and install a Detroit truetrac.
As a thpught I would contact Auburn Gear and see if they can get a Select a lock limited stip for you. It is a diff that has both Elocker capabilities with a limited slip when not locked and is a stronger design compared to the conventional E-Locker.
Superdannyboy
Thanks French
7Boomerang7
Ash
Washington State
2020 Ranger XLT Crew Cab 4X4 / Lightning Blue
Hey friends, I’m wanting to buy the terrain management switch for my XLT. Looks like a 5 minute install. I don’t have a PC based laptop, only Mac, so I can’t easily buy Forscan and do that myself. If I install the switch myself and have Ford do the computer work on my next oil change am I voiding any warranties? I would also be buying the switch online from a specific dealer of genuine parts that has the switch for $40 off so I was hoping to save $ there plus probably whatever ridiculous amount of $ Ford would want for a 5 minute job. Thanks!
