3" spacers on Tremor
Bludrok
Acampo, California
www.ranger5g.com
I got some 3" spacers and put them on to fit for rubbing, etc. I had to remove the front crash bar and stock front mud flap. Fit great after that, except my wheel studs arent long enough, so I have to pull it back off for now.
Here is what it looks like on just 1 wheel:
OFC Ranger
Jack
ZR2
The larger the spacer, the more clearance/rubbing problems you create. Not sure what it is you are after here as you ultimately had to remove parts anyhow.
Raising the vehicle height will resolve clearance issues, not pushing the wheels out.
Edit: Sorry I read that as "fix" not "fit".
Disregard.
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
Disregard.
No worries, lol. I just wanted a more aggressive stance. I'm very happy with the look, just need to get some longer wheel studs to make em work.
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
AZ Tremor
Peoria,AZ
2021 Tremor Lariat
What brand?
Hack_Actual
Justin
Oklahoma
2019 Ford Ranger Lariat FX4
Be careful, amigo. A 3" spacer is dangerous territory, in my opinion. Looking at your profile picture you at least occasionally dabble in off-road type shenanigans and I think you're setting yourself up for some catastrophic failure.
If you want the look get some wheels with a better offset and retain your current tires to help mitigate the cost.
Cpore55
CJ Pore
Kansas
2021 Ranger Tremor
Inventory planner- Meat solutions
Will any spacers fit so long as correct bolt pattern?
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
You need to match up bolt pattern and center bore size (93.1 is factory size) assuming you use hubcentric spacers, which is recommended. You can also go with a larger center bore on the spacer if you use hubrings. Also have to make sure your existing wheel studs are long enough.
Don't use cheap crap, make sure to go with a reputable company.
Cpore55
CJ Pore
Kansas
2021 Ranger Tremor
Do you know will a 1.5 inch spacer go on a tremor without rub issue? I have the one inch level kit
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
I dont know. I'm sure it would work, but you may need to remove the crash bars.
