3” level kit 285/75/16 BFG KO2
Can I cut crash bar with a sawzall?
  • Total voters
Julie dominesey
Julie
2019 ford ranger xlt fx4 and a 2018 Ford f 150 xlt fx4
What is wheel measurement ? Off set and backspace ?
earsmccoy
Matthew
Southern California
2019 Ranger Screw XLT FX4 Sport Package & 2016 F-150 Super Crew FX4
Too tight to cut it with a Sawzall but you can get at it with a grinder/cut off wheel. At least I don't think so. It took some finessing with a cut off wheel.
WH_a-ZRUwai6enre8IrtI8vWA8F0361IHkzTtUwf3XDgHdpaPJHjKZIg_C9erD4pqfNftfewevbCmpMt-8K=w293-h220...webp
BjWRO9KiXHOQP4ONGpa13Y_DdGXXzl3j92p3bgGdaysH7vsO52bURx_4KoQ2LzAuAVLny5udVo8A9Vz-b=w2390-h1792-no.jpg
HoosierT
Tyler
Fishers, IN
The Fabtech instructions for their crash bars actually say to use a SawZaw. While I myself used an angle grinder, I actually think a sawzaw would have been easier is I owned one.
TigerWoodsG5
TigerWoodsG5
Jerry
San Antonio
2019 XLT Ford Ranger
Did you have to take tire off?
Johnpenn
Rockwood TN
2019 Ranger Lariat FX4, 2004 Corvette, 2005 Ranger Edge
Retired Quality and EHS Manager
I can't recall where I saw it but one of the lift kit supplier's instructions said to remove the thru bolt and just slide it out of the frame tube. Has anyone done this? I don't have my Ranger yet to try it myself but plan to install a kit when I get the truck.
FULLSCALE
Adam
Ontario, Canada
An oscillating tool would also be a good choice if you have a long enough blade.
HoosierT
Tyler
Fishers, IN
You can slide it out if you want to remove the bumper and fender but that’s a lot of work.
Johnpenn
Rockwood TN
HoosierT
Tyler
Fishers, IN
I guess so. Thanks.
To clarify, myself and others have totally removed the beams my removing the bolts but there isn’t enough room to slide them out. As such, it’s a two-step process. Cut the beams to provide clearance, then remove the bolts and slide out the remainder of the beam. Here it is after complete removal.
TigerWoodsG5
TigerWoodsG5
Jerry
San Antonio
Need a pneumatic drill to get those bolts off. They are torqued on there pretty good. I cut the crash bar off yesterday with a sawzall
Julie dominesey
Julie
Step one I’m buying these wheels 18x9... putting stock tires on these wheels .. step 2 going up 2.5” in the front ... step 3 putting a 265/70 18 on the stock wheel with not so aggressive tread .. then on the fuel wheels they will get a 275 70 18 durattrac .. going to a 285 creates too much hassle
VetteBro
Santa Clarita, CA
2019 Ford Ranger LT4 Sport 4x4, 2016 Corvette z06, 2013 Ford Focus ST
Very helpful comments guys. Did any of you have any plans to swap the removed crash bar with a modified one (if such a thing exists)?
My biggest problem is on the drivers side. I did a 3” leveling lift with 285/55R20s. Passenger side is fine.
ToothRanger
Kyle
South Texas
D.D.S.
@VetteBro they do exist.
Both FabTech and ProComp offer kits with modified intrusion bars. FabTech has them available to purchase separately. ProComp only offers their's with a lift kit.
https://www.ranger5g.com/forum/thre...-options-for-the-2019-ranger.2090/#post-29423
