2021 fx4 off road screen question.
Crow_of_judgement
William
20 ranger screw lariat
WingShot
Andrew
Denver, CO
2021 XLT, Tremor, Cactus Gray
Graphic Artist
It shows the "pitch" and "roll" angles of the truck while off roading. Not exactly a gimmick, but not that useful either. The times when I need to know that info, I'm too busy trying not to roll over to bother looking at the instrument cluster.
Crow_of_judgement
Crow_of_judgement
William
Interesting. I suppose that would be fun to look at occasionally
Tom_C
Virginia, USA
System Admin, Retired
When you're not driving.
JK, I have it, but I haven't been off road, and like said above, I wouldn't be paying attention to it if I were. Maybe I'd get somewhere safe and stop, then check it out.
You can actually enable that with Forscan on Non FX4 or Tremor.
That’s one of the changes I did and never use.
Ref the Forscan Wiki
Off Rad Screen
I have this screen enabled, cool but have never used it
If I recall when this screen is displayed the TM - Terrain Mgmt also populates here as well, if you have it out of 2-Wheel Drive
I can't remember which of the (2) Screens it does it on.
And if you have the E-Liocker, this screen is also an option.
I enabled this screen as well but useless on a non (E-Locker) Truck as it shows nothing.
This screen is - Intelligent 4-WD - In Forscan
Off Road GaugeEnables Off-road gauges (enable in conjunction with Off-road Screen)IPCGizmokid2005
Off-road ScreenEnables off-road gauges (enable in conjunction with Off Road Gauge)IPC720-07-02 (x3xx xxxx xxxx)Gizmokid2005 / WhiteLightning19 (AS-BUILT)
Silverfox
Ed
Mississauga
2020 xlt sport 4x4
Tech
I don’t find the angles are that accurate . Especially when you’re on flat ground and start up an incline. The truck is usually nose up 15-20 degrees before it register's anything. Although mine is a sport. I enabled it using forescan.
The interesting part about the Roll and Pitch gauges is the Ranger does not have a particular rated area of Roll. I know my old 93 Pathfinder states in the owners manual to not exceed 30° in Roll and Pitch. It is pottye Ranger would be around that. That said if you don't travel OffRoad then chances are it would be useless to you
the off road screens are worth it! two rangers are better than one go for it lol.
Mighty Little Blue
Printer/Retired
What is the small button below the Terrain Management button for (shown in the 8th photo)? I have a 2021 Lariat FX4 and do not have that button?
LT Dangle
Brett
New York
21 FX4 (RIP), 21 Tremor, 20 Edge ST, Couple HD's
Trophy Husband / "Sanitation Worker" / Army Vet
In the dealers listing? it looks like the Redarc trailer brake controller. Also sold by Ford as an accessory but its not mounted where recommended.
Borrowed Pic from another member install
