2019 Ford Ranger Reviews Compilation
Crismac
Cris
Kansas City , Missouri
1998 Ford Ranger XLT, 2019 Ford Ranger XLT
Railroad Conductor
At 07:00 he talks about a plastic piece on the dash behind the storage bin that rattles really bad on rough terrain. I have not heard of this complaint before. Has anyone else seen or heard of this problem?
rangerdanger
SF Bay Area
That's where the 10th speaker goes in the Lariat 501A B&O premium audio system. In all other trucks they must cover it with a piece of plastic. It should be a simple fix to stop it rattling.
Ron_W
Ron
Illinois
2017 Escape titanium, 2013 c-max
Don't remember seeing this one, if I uploaded it correctly. They actually lift the FX4 and walk under it. Posting 242 in this forum, right at the beginning backs a 4x4 over a camera showing the underside.
Thanks for posting it. This makes me feel a LOT better about the transmission pan. Previously, I had seen postings stating there was no skid plate on the transmission (which there isn't) and that it has a plastic pan (which it does). In this video you can see the transmission is pretty well protected. It sits at least a couple inches above the bottom of the frame and has some other metal protecting it (not sure what they were). Unless you happened to drive over a bendy branch that came back and smacked the transmission pan it seems like it is pretty well protected to me.
One of the things the early marketing videos showed was that they tucked everything up inside the frame. That really impressed me. None of the other competitors do that. In fact, I think the Tacomas effective ground clearance is the same or maybe slightly less than the Ranger due to their crossover pipe hanging down. But maybe they measure the ground clearance from the bottom of that crossover pipe. I still like how they did a nice job tucking everything inside the frame.
t4thfavor
Chance
It's tucked up there, but I can see a rock or branch getting it. It's probably the first thing I'm going to change. I'll build a 1/4" steel plate to go from the front skid to the next crossmember, or I'll get a metal trans pan if one is available.
I will be interested to see what you come up with if you build a plate for it.
Desert_5G
Eric
Arizona
Tacoma
Toytec
Central NC
More money than sense. I needed a good chuckle today. This filled my needs.
At least he admitted he was an idiot..... :crackup:
FX4Offroad
South Florida
2019 Lariat FX4
haha. can't believed he called a tow truck. all he needed was a little pull with a tow strap from a buddy.
Yeah...he did admit that he didnt know what he was doing. It was unusual to see someone take 100% responsibility for that.
Glad it ended up ok.
