Can only comment that my'19 @ 29K is with transmission problems - back in the shop now.What are the most common issues with the 2019s. I keep most of my vehicles 10+ years usually drive it till it blows up. My Nissan Murano made it 15 years 250k
This ford ranger is already making me worry. AC issue, fuel censr failure. Do you think these trucks will last or should I sell it while it has value. Just quirious if anyone else's has felt this way?
Not one problem? Water pump, ball joint, steering shaft. Sounds like 3 problems.There is NO WAY I expect my 2022 LARIAT
/ TREMOR to last w/o problems the way my 2003 Tacoma did. Other than a water pump, a ball joint, and steering shaft, in 100k not one problem.
Technical, he's correct I guess ? ? ?, but I am more than willing to trade some reliability for something thats fun to drive, give me a 50000 mile Ranger versus 100000 mile Tacoma any damn day, life's too short to be bored behind the wheel!!!Not one problem? Water pump, ball joint, steering shaft. Sounds like 3 problems.
Why do they list a different part# for the Ranger transmission filter?Here is the tranny TSB,
TECHNICAL SERVICE BULLETIN
10R80 Automatic Transmission - Harsh/Delayed Engagement And/Or Harsh/Delayed Shift - Non-Main Control Break-In Capable 24-2101
28 March 2024This bulletin supersedes 24-2046. Reason for update: revise the Service Procedure LTIS statement
Model:
Markets: Published by Ford North America
Ford
2018-2021 ExpeditionTransmission/Transaxle: 10R80 2017-2020 F-150 Transmission/Transaxle: 10R80 2018-2021 Mustang Transmission/Transaxle: 10R80 2019-2023 Ranger Transmission/Transaxle: 10R80 Lincoln
2018-2021 NavigatorTransmission/Transaxle: 10R80
Issue: Some 2017-2020 F-150, 2018-2021 Expedition/Navigator/Mustang, 2019-2023 Ranger vehicles equipped with a 10R80 transmission may exhibit a harsh/delayed engagement and/or harsh/delayed shift, an illuminated MIL with DTC P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7 stored in the PCM or TCM. This may be due to the transmission solenoid ID strategy, sticking valves in the main control valve body and/or axial movement of the CDF clutch cylinder (7H351) sleeve. To correct the condition, follow the Service Procedure to identify and correct the condition.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
Parts - All Vehicles - Main Control Overhaul
Parts - All Vehicles - Main Control Overhaul - Parts To Inspect And Replace Only If Necessary
Service Part Number Claim Quantity Package Order Quantity Number in Package Description W712658-S439 2 1 4Solenoid Retaining Plate Bolt HL3Z-7G007-A 6 6 1Solenoid Retaining Clips JL1Z-7N134-A 1 1 1Park Override Bolt (Expedition/Navigator) XT-12-QULV As Needed As Needed Motorcraft® MERCON® ULV Automatic Transmission Fluid
Parts - All Vehicles - CDF Cylinder Replacement
Service Part Number Claim Quantity Package Order Quantity Number in Package Description HL3Z-7A191-B Only If Necessary Only If Necessary 1Fluid Pan Gasket L1MZ-7A098-A Only If Necessary Only If Necessary 1Fluid Filter (F-150/Expedition/Navigator/Mustang/Explorer) HL3Z-7A098-A Only If Necessary Only If Necessary 1Fluid Filter (Ranger) 7T4Z-7Z302-A Only If Necessary Only If Necessary 1Transmission Fluid Filter Seal HL3Z-7J227-A Only If Necessary Only If Necessary 1Auxiliary Pump Tube O-ring (If Equipped) HL3Z-7Z490-E Only If Necessary Only If Necessary 1Chanel Plate HL3Z-7Z490-D Only If Necessary Only If Necessary 1Separator Plate (2017 F-150) JL1Z-7Z490-C Only If Necessary Only If Necessary 1Separator Plate (Expedition/Navigator With Electronic Gearshift) JL3Z-7Z490-E Only If Necessary Only If Necessary 1Separator Plate (Expedition/2018-2020 F-150 Without Electronic Gearshift, All Ranger) JL3Z-7Z490-D Only If Necessary Only If Necessary 1Separator Plate (Mustang Built On Or Before 3-Jan-2021) L1MZ-7Z490-J Only If Necessary Only If Necessary 1Separator Plate (Mustang Built On Or After 4-Jan-2021)
Parts - All Vehicles - CDF Cylinder Replacement - Parts To Inspect And Replace Only If Necessary
Service Part Number Claim Quantity Package Order Quantity Number in Package Description HL3Z-7G199-A 1 1 1Auxiliary Pump Tube Seal (Stop/Start) HL3Z-7A248-A 1 1 1Torque Converter Seal JL3Z-7N134-A 12 12 1Front Support Bolts LC3Z-7H223-A 12 12 1Front Support Bolt Seals HL3Z-7A248-G 1 1 1Front Support To Case Seal HL3Z-7G091-F 5 5 1Input Shaft Seals (F2) HL3Z-7B399-C 4 4 1Sun Gear No. 3 Shaft Seals (F7) HL3Z-7C099-A 1 1 1C Clutch Balance Dam Inner Seal HL3Z-7A548-B 2 2 1C Clutch Balance Dam And Piston Outer Seal HL3Z-7D404-A 2 2 1C And D Clutch Piston Inner Seals HL3Z-7A262-C 1 1 1D Clutch Balance Dam HL3Z-7D403-A 1 1 1D Clutch Piston Outer Seal HL3Z-7A548-G 2 2 1F Clutch Balance Dam And Piston Outer Seal HL3Z-7A548-A 2 2 1F Clutch Balance Dam And Piston Inner Seal HL3Z-7G091-G 5 5 1Input Shaft To Sun Gear No. 3 Shaft Seals (F8) HL3Z-7G091-C 1 1 1Input Shaft Seal (F9) JL3Z-7H351-B 1 1 1CDF Cylinder (F-150/Expedition/Navigator, 5.0L Mustang) JR3Z-7H351-B 1 1 1CDF Cylinder (Ranger/2.3LMustang)
Parts - All Vehicles - CDF Cylinder Replacement - Select One Of The Following If Needed
Service Part Number Claim Quantity Package Order Quantity Number in Package Description HL3Z-7B066-AB Only If Necessary Only If Necessary 1A Clutch Pressure Plate HL3Z-7B164-E Only If Necessary Only If Necessary 1A Clutch Friction Plates HL3Z-7F220-A Only If Necessary Only If Necessary 1A Clutch Steel Plates HL3Z-7B442-F Only If Necessary (Ranger Has 4 Pieces, F-150/Mustang/Expedition/Navigator Have 5 Pieces) Only If Necessary 1C Clutch Steel Plates HL3Z-7B164-A Only If Necessary (Ranger Has 4 Pieces, F-150/Mustang/Expedition/Navigator Have 5 Pieces) Only If Necessary 1C Clutch Friction Plates ML3Z-7B477-A Only If Necessary Only If Necessary 1C Clutch Pressure Plate HL3Z-7B442-D Only If Necessary (Ranger Has 5 Pieces, F-150/Mustang/Expedition/Navigator Have 6 Pieces) Only If Necessary 1D Clutch Steel Plates HL3Z-7B164-C Only If Necessary (Ranger Has 5 Pieces, F-150/Mustang/Expedition/Navigator Have 6 Pieces) Only If Necessary 1D Clutch Friction Plates HL3Z-7B066-E Only If Necessary Only If Necessary 1D Clutch Pressure Plate HL3Z-7B164-G Only If Necessary (Ranger Has 3 Pieces, F-150/Mustang/Expedition/Navigator Have 4 Pieces) Only If Necessary 1F Clutch Steel Plates HL3Z-7B164-D Only If Necessary (Ranger Has 3 Pieces, F-150/Mustang/Expedition/Navigator Have 4 Pieces) Only If Necessary 1F Clutch Friction Plates HL3Z-7B066-A Only If Necessary Only If Necessary 1F Clutch Pressure Plate
Parts - F-150/Expedition/Navigator Transmission Removal And Installation
Service Part Number Claim Quantity Package Order Quantity Number in Package Description HL3Z-7B066-AA Only If Necessary Only If Necessary 1A Clutch Apply Plate 4.1 - 4.3 mm Selective HL3Z-7B066-Z Only If Necessary Only If Necessary 1A Clutch Apply Plate 4.4 - 4.6 mm Selective HL3Z-7B066-Y Only If Necessary Only If Necessary 1A Clutch Apply Plate 4.7 - 4.9 mm Selective HL3Z-7B066-X Only If Necessary Only If Necessary 1A Clutch Apply Plate 5.0 - 5.2 mm Selective HL3Z-7B066-W Only If Necessary Only If Necessary 1A Clutch Apply Plate 5.3 - 5.5 mm Selective HL3Z-7H032-C Only If Necessary Only If Necessary 1T-3 Bearing (Replace If T-3 Shim Is Replaced) HL3Z-7A527-Q Only If Necessary Only If Necessary 1T-3 Shim 3.05-3.15 mm Selective HL3Z-7A527-P Only If Necessary Only If Necessary 1T-3 Shim 3.2-3.3 mm Selective HL3Z-7A527-R Only If Necessary Only If Necessary 1T-3 Shim 3.35-3.45 mm Selective HL3Z-7A527-K Only If Necessary Only If Necessary 1T-3 Shim 3.5-3.6 mm Selective HL3Z-7A527-L Only If Necessary Only If Necessary 1T-3 Shim 3.65-3.75 mm Selective HL3Z-7A527-M Only If Necessary Only If Necessary 1T-3 Shim 3.8-3.9 mm Selective HL3Z-7A527-S Only If Necessary Only If Necessary 1T-3 Shim 3.95-4.05 mm Selective HL3Z-7A527-T Only If Necessary Only If Necessary 1T-3 Shim 4.1-4.2 mm Selective HL3Z-7A527-N Only If Necessary Only If Necessary 1T-3 Shim 4.25-4.35 mm Selective HL3Z-7D483-A Only If Necessary Only If Necessary 1D Clutch Snap Ring 1.8 mm Selective HL3Z-7D483-B Only If Necessary Only If Necessary 1D Clutch Snap Ring 2.0 mm Selective HL3Z-7D483-C Only If Necessary Only If Necessary 1D Clutch Snap Ring 2.2 mm Selective HL3Z-7D483-D Only If Necessary Only If Necessary 1D Clutch Snap Ring 2.4 mm Selective HL3Z-7D483-E Only If Necessary Only If Necessary 1D Clutch Snap Ring 2.6 mm Selective HL3Z-7D483-F Only If Necessary Only If Necessary 1D Clutch Snap Ring 2.8 mm Selective HL3Z-7C122-A Only If Necessary Only If Necessary 1C Clutch Snap Ring 1.5 mm Selective HL3Z-7C122-B Only If Necessary Only If Necessary 1C Clutch Snap Ring 1.7 mm Selective HL3Z-7C122-C Only If Necessary Only If Necessary 1C Clutch Snap Ring 1.9 mm Selective HL3Z-7C122-D Only If Necessary Only If Necessary 1C Clutch Snap Ring 2.1 mm Selective HL3Z-7C122-E Only If Necessary Only If Necessary 1C Clutch Snap Ring 2.3 mm Selective HL3Z-7C122-F Only If Necessary Only If Necessary 1C Clutch Snap Ring 2.5 mm Selective HL3Z-7H365-C Only If Necessary Only If Necessary 1F Clutch Snap Ring 1.5 mm Selective HL3Z-7H365-D Only If Necessary Only If Necessary 1F Clutch Snap Ring 1.7 mm Selective HL3Z-7H365-E Only If Necessary Only If Necessary 1F Clutch Snap Ring 1.9 mm Selective HL3Z-7H365-F Only If Necessary Only If Necessary 1F Clutch Snap Ring 2.1 mm Selective HL3Z-7H365-G Only If Necessary Only If Necessary 1F Clutch Snap Ring 2.3 mm Selective
Parts - F-150/Expedition/Navigator Transmission Removal And Installation - Parts To Inspect And Replace Only If Necessary
Service Part Number Claim Quantity Package Order Quantity Number in Package Description Note 7L1Z-4B496-C 2 2 1CV Joint-To-Pinion Flange Cup Bolts And Retaining Straps (4WD) FL3Z-6775-D 1 1 1Self-Adhesive Heat Shield 7L1Z-4B496-D 3 3 1CV Joint-To-Transfer Case Flange Cup Bolts And Retaining Straps (4WD Expedition/Navigator) JL1Z-7N134-A 1 1 1Park Override Lever Bolt (Non-Column Shift Expedition/Navigator) FL3Z-5C226-A 2 2 1Left And Right Catalytic Converter Gasket (F-150 2.7L) W520113-S440 4 1 4Stabilizer Bar Bracket Nuts W520114-S442 4 1 4Transmission Support Crossmember Nuts W520514-S440 4 4 1Left And Right Catalytic Converter Nuts (All Gas Non-Hybrid) W704980-S439 1 1 4Park Manual Release Cable Bracket Bolt (F-150 Gas/Hybrid) W709771-S440 2 2 1Transmission Mount Nuts W711140-S901 3 3 1Transmission Insulator Bolts And Washers (RWD Gas) W714418-S439 4 1 4Transmission Support Crossmember Bolts W715131-S437 1 1 4Transmission Fluid Cooler Tube Bracket Bolt (Expedition/Navigator) W715618-S437 Gas Engines Require 4 Pieces, Diesel Engine Require 6 Pieces 1 For Gas, 2 For Diesel 4Torque Converter Nuts Does not apply to hybrid W715798-S442 1 1 4Fluid Cooler Tube Stud Bolt (3.0L) / Park Manual Release Cable Bracket Bolt (3.5L) W716375-S900 9 2 5Transfer Case Bolts (4WD) W718353-S900 4 1 4Transmission Insulator Bolts (4WD) (Gas/Hybrid) W718926-S900 4 1 4Transmission Insulator Bolts (4WD) (Diesel) W715579-S439 2 1 4Driveshaft Center Bearing Bolt (If Equipped With Two Piece Driveshaft) TA-24-B As Needed As Needed Motorcraft® Thread Sealant With PTFE (4WD) VC-13DL-G As Needed As Needed Motorcraft® Yellow Prediluted Antifreeze/Coolant (All Markets Except Canada) CVC-13DL-G As Needed As Needed Motorcraft® Yellow Prediluted Antifreeze/Coolant (Canada Only) XG-1-E1 As Needed As Needed Motorcraft® Premium Long-Life Grease XL-5-A As Needed As Needed Motorcraft® Multi-Purpose Grease Spray XT-10-QLVC As Needed As Needed Motorcraft® MERCON® LV Automatic Transmission Fluid (4WD) (All Markets Except Canada) Transfer Case Fluid CXT-10-LV6 As Needed As Needed Motorcraft® MERCON® LV Automatic Transmission Fluid (4WD) (Canada Only) Transfer Case Fluid XT-12-QULV As Needed As Needed Motorcraft® MERCON® ULV Automatic Transmission Fluid
Parts - F-150/Expedition/Navigator Transmission Removal And Installation - Rear Driveshaft Bolts And Straps (Not All Vehicles Will Use All Of The Parts Listed)
Service Part Number Claim Quantity Package Order Quantity Number in Package Description 4W9Z-6397-A Only If Necessary Only If Necessary 1Engine Block Dowel Pins (3.0L) 5L7Z-7D285-A Only If Necessary Only If Necessary 2Transmission Fluid Cooler Tube Seals (3.0L/3.5L) 5L7Z-7J324-A Only If Necessary Only If Necessary 2Transmission Fluid Cooler Tube Backing Rings (3.0L/3.5L) ML3Z-4421-A Only If Necessary Only If Necessary 1Front Driveshaft Slip Yoke Boot W701228-S300 Only If Necessary Only If Necessary 4Engine Block Dowel Pins (5.0L) W718758-S300 Only If Necessary Only If Necessary 4Engine Block Dowel Pins (2.7L/3.3L/3.5L)
Parts - Mustang Transmission Removal And Installation
Service Part Number Claim Quantity Package Order Quantity Number in Package Description W500635-S439 1 1 1Driveshaft Center Bearing Bolt (If Equipped With Two Piece Driveshaft) W713095-S437 1 1 4Driveshaft Center Bearing Nut (If Equipped With Two Piece Driveshaft) W719738-S439 1 1 4Driveshaft Center Bearing Bracket Mounting Stud (If Equipped With Two Piece Driveshaft) N800594-S100 4 Or 8 (Flange Dependent) 1 Or 2 4Driveshaft Flange To Flange Bolts (F-150) N811880-S100 4 Or 8 (Flange Dependent) 1 Or 2 4Driveshaft Flange To Flange Bolts (Expedition/Navigator)
Parts - Mustang Transmission Removal And Installation - Parts To Inspect And Replace Only If Necessary
Service Part Number Claim Quantity Package Order Quantity Number in Package Description BR3Z-5B266-A 1 1 1Exhaust Gasket (5.0L) W705443-S900 2 1 4Catalytic Converter Flange Nuts (5.0L) W710726-S437 2 1 4Selector Lever Cable Bolts W715131-S437 1 1 4Transmission Fluid Cooler Tube Bolt W715618-S437 5.0L Require 4 Pieces, 2.3L Require 6 Pieces 1 For 5.0L, 2 For 2.3L 4Torque Converter Nuts FR3Z-4B496-B 3 3 1Driveshaft To Pinion Flange Bolts W719298-S439 3 1 4Driveshaft To Transmission Flange Bolts (If Equipped) (2.3L) N800594-S101 4 1 4Driveshaft To Transmission Flange Bolts (If Equipped) (5.0L) W500545-S439 3 1 4Driveshaft To Transmission Flange Bolts W717822-S439 2 1 4Driveshaft Center Bearing Bolts (If Equipped) TA-25-B As Needed As Needed Motorcraft® Threadlock and Sealer (Convertible) XL-1 As Needed As Needed Motorcraft® Penetrating and Lock Lubricant XL-2 As Needed As Needed Motorcraft® High Temperature Nickel Anti-Seize Lubricant XL-5-A As Needed As Needed Motorcraft® Multi-Purpose Grease Spray XT-12-QULV As Needed As Needed Motorcraft® MERCON® ULV Automatic Transmission Fluid
Parts - Ranger Transmission Removal And Installation
Service Part Number Claim Quantity Package Order Quantity Number in Package Description 5L7Z-7D285-A Only If Necessary Only If Necessary 2Transmission Fluid Cooler Tube Seals 5L7Z-7J324-A Only If Necessary Only If Necessary 2Transmission Fluid Cooler Tube Backing Rings JR3Z-4782-B Only If Necessary Only If Necessary 1Flex Coupling Driveshaft
Parts - Ranger Transmission Removal And Installation - Parts To Inspect And Replace Only If Necessary
Service Part Number Claim Quantity Package Order Quantity Number in Package Description Note JB3Z-4B496-B 6 6 1CV Joint-To-Transfer Case And Pinion Flange Bolts And Retaining Straps (4WD) BE8Z-6731-AB 1 1 1Engine Oil Filter And Gasket (4WD) KB3Z-6L612-A 1 1 1Catalytic Converter Gasket W500121-S437 9 3 4Transfer Case Bolts (4WD) W500642-S437 4 4 1Transmission Support Insulator Bolts (4WD) W700056-S450B 2 1 4Selector Lever Cable Bracket Bolts W714265-S442 3 1 4Catalytic Converter Nuts W715618-S437 6 2 4Torque Converter Nuts W716936-S442 2 2 1Stabalizer Bar Bracket Nuts W719427-S439 2 1 4Stabalizer Bar Bracket Bolts W710233-S437 4 4 1Driveshaft Flange To Pinion Flange Bolts W714780-S439 2 1 4Driveshaft Center Bearing Bolt (If Equipped With Two Piece Driveshaft) W716344-S437 4 4 1Driveshaft Flange To Transmission Flange Bolts PM-4-A As Needed As Needed Motorcraft® Metal Brake Parts Cleaner (Compliant With Low Volatile Organic Compound Requirements As Required In Some USA States) PM-4-B As Needed As Needed Motorcraft® Metal Brake Parts Cleaner (Not Compliant With Volatile Organic Compound Requirements) XL-2 As Needed As Needed Motorcraft® High Temperature Nickel Anti-Seize Lubricant XL-5-A As Needed As Needed Motorcraft® Multi-Purpose Grease Spray XO-5W30-Q1SP As Needed As Needed Motorcraft® SAE 5W-30 Synthetic Blend Motor Oil (All Markets Except Canada) CXO-5W30-LSP6 As Needed As Needed Motorcraft® SAE 5W-30 Super Premium Motor Oil (Canada Only) XT-10-QLVC As Needed As Needed Motorcraft® MERCON® LV Automatic Transmission Fluid (4WD) (All Markets Except Canada) Transfer Case Fluid CXT-10-LV6 As Needed As Needed Motorcraft® MERCON® LV Automatic Transmission Fluid (4WD) (Canada Only) Transfer Case Fluid XT-12-QULV As Needed As Needed Motorcraft® MERCON® ULV Automatic Transmission Fluid
Claim Quantity refers to the total number of individual pieces required to repair the vehicle.
Service Part Number Claim Quantity Package Order Quantity Number in Package Description JB3Z-7J227-A Only If Necessary Only If Necessary 1Transmission Fluid Cooler Tube Seals W701183-S1300 Only If Necessary Only If Necessary 4Engine Block Dowel Pins (2.3L)
Package Order Quantity refers to the amount of the service part number package(s) required to repair the vehicle.
Number In Package refers to the number of individual pieces included in a service part number package.
As Needed indicates the amount of the part may vary and/or is not a whole number. Parts can be billed out as non-whole numbers, including less than 1.
Only If Necessary indicates the part is not mandatory.
Warranty Status: Information Only.
Repair/Claim Coding
Causal Part: IN Condition Code: 42
Service Procedure
NOTE: This article is for information only. Determine the causal part number and use available labor times in Section 7 of the SLTS Manual or claim M-time in accordance with the Warranty and Policy Manual. Causal part number IN in this article refers to the information only status and is not able to be claimed.
1. Using the latest software level of the appropriate Ford diagnostic scan tool, check for DTCs.
2. Are any of the following DTCs present? P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7.
(1). Yes - proceed to Sticking Valves - Main Control Valve Body Step 1.
(2). No - proceed to Transmission Solenoid Strategy Step 1.
1. Reprogram the existing transmission strategy download into the PCM/ TCM. Refer to WSM, Section 307-01.
(1). For FDRS applications when prompted, select Transmission hardware was not replaced - Reprogram TRID strategy for the existing transmission.
(2). For IDS applications when prompted, select Reprogram Only-No Hardware Replaced.
2. Perform the adaptive learning drive cycle. Refer to WSM, Section 307-01.
3. Does the vehicle still exhibit the condition after performing the adaptive learning drive?
(1). Yes - proceed to Sticking Valves - Main Control Valve Body, Step 1.
(2). No - repair is complete.
NOTE: Advise the customer this vehicle is equipped with an adaptive transmission shift strategy which allows the vehicle's computer to learn the transmission's unique parameters and improve shift quality. When the adaptive strategy is reset, the computer will begin a relearning process. This relearning process may result in firmer than normal upshifts and downshifts for several days.
NOTE: Affected vehicles are not main control break-in capable.
1. Overhaul (clean and inspect) the main control valve body and perform the adaptive learning drive cycle. Refer to WSM, Section 307-01.
2. Does the vehicle still exhibit the condition after overhauling the main control valve body and performing an adaptive learning drive cycle?
(1). Yes, vehicles built on or before 15-Aug-2022 - proceed to CDF Clutch Cylinder Replacement Step 1.
(2). Yes, vehicles built on or after 16-Aug-2022 - this article is complete. Refer to WSM, Section 307-01 for normal diagnostics.
(3). No - repair is complete.
NOTE: Advise the customer that this vehicle is equipped with an adaptive transmission shift strategy which allows the vehicle's computer to learn the transmission's unique parameters and improve shift quality. When the adaptive strategy is reset, the computer will begin a relearning process. This relearning process may result in firmer than normal upshifts and downshifts for several days.
NOTE: For Mexico, U.S. and Canadian vehicles which are low time in service (LTIS) policy eligible, the dealer has the option to continue with this TSB repair or replace the transmission under the LTIS policy.
1. Remove the transmission and mount the transmission to the bench. Refer to WSM, Section 307-01.
2. Disassemble the transmission. Perform only the necessary steps to remove the clutch and planetary assembly from the transmission case. Refer to WSM, Section 307-01.
(1). It is only necessary to remove the torque converter, transmission fluid pan and gasket, transmission fluid auxiliary pump (if equipped), fluid filter and main control valve body assembly, all 4 speed sensors (intermediate speed sensor A [ISSA], intermediate speed sensor B [ISSB], turbine shaft speed [TSS] and output shaft speed [OSS]), transmission fluid pump, front support assembly and the clutch and planetary assembly. Refer to WSM, Section 307-01.
3. Disassemble the clutch and planetary assembly. Perform only the necessary steps to remove the CDF clutch cylinder and the No. 3 sun gear shaft and No. 2 ring gear assembly from the clutch and planetary assembly. Refer to WSM, Section 307-01.
(1). It is only necessary to remove the A clutch assembly, the selective shim and T3 thrust bearing, remove and discard the 5-input shaft front seals.
(2). Remove the No. 1 planetary carrier snap ring, clutch, and planetary container cylinder, the E clutch and input shaft assembly, the No. 3 planetary carrier and No. 3 sun gear, the No. 3 sun gear shaft and No. 2 ring gear assembly. Refer to WSM, Section 307-01.
4. Remove and discard the sun gear No. 3 shaft seals. Install the 4 new sun gear No. 3 shaft seals. Refer to WSM, Section 307-01.
5. Disassemble the C, D and F clutch assemblies from the CDF cylinder. Discard the CDF cylinder. Refer to WSM, Section 307-01.
6. Assemble the C, D and F clutch assemblies into the new CDF clutch cylinder. Refer to WSM, Section 307-01.
7. Perform the C, D and F clutch pack endplay measurements for proper clearance. Refer to WSM, Section 307-01.
8. Remove and discard the input shaft-to-sun gear No. 3 shaft seals. Install the 5 new input shaft-to-sun gear No. 3 shaft seals. Refer to WSM, Section 307-01.
9. Remove and discard the input shaft seal. Install the new input shaft seal. Refer to WSM, Section 307-01.
10. Install the 5 new input shaft front seals. Refer to WSM, Section 307-01.
11. To reassemble the clutch and planetary assembly, reverse the disassembly procedure. Refer to WSM, Section 307-01.
12. Perform the T3 thrust bearing measurement to set transmission front end clearance. Refer to WSM, Section 307-01.
13. Reassemble the transmission. Refer to WSM, Section 307-01.
14. Install the transmission. Refer to WSM, Section 307-01.
15. Perform an adaptive learning drive cycle. Refer to WSM, Section 307-01.
Check your DM's.Can you access the oasis reports? I bought mine used from a non ford dealer and would really like to know if it had anything done being as I’m the third owner.
108k miles on my 2021 i bought new. No issues at all. Just general maintenance. Have faith lolWhat are the most common issues with the 2019s. I keep most of my vehicles 10+ years usually drive it till it blows up. My Nissan Murano made it 15 years 250k
There’s a maverick raptor ??? Wow I wonder what that’s gonna be like.Sell it.
Buy a 2024 ranger raptor.
Or a maverick raptor
They are ADORABLE!!!There’s a maverick raptor ??? Wow I wonder what that’s gonna be like.
