2019 ford ranger lariat 97,000 miles should I sell or keep.
Ranger Lariat
Earth
Hot Wheel
If you can afford to get away from the Ford I would. You won’t get much for it with that mileage, but it’s still running so you’ll get something $.
There is NO WAY I expect my 2022 LARIAT
/ TREMOR to last w/o problems the way my 2003 Tacoma did. Other than a water pump, a ball joint, and steering shaft, in 100k not one problem. Yes, tires, shocks and fluids, and batteries, but seriously in 18 years / 100k that’s it. My Ford, with now 8k mi, I hold my breath every time I start it or the transmission shifts. Sooooo why don’t I have another TACO? Because I’m 6’4” (210lbs), and if you know Tacomas you know if you’re over 6’ you don’t fit. Twenty years ago I “lived” with that because i wanted the truck. Now I drive a Ranger only because I fit in it.
Seems like if you make it over about 60k in the Ford you’ve been lucky?
WheelMon
Otto
Vallejo, CA
autio.com
@Autio Travel App by Kevin Costner
What are the most common issues with the 2019s. I keep most of my vehicles 10+ years usually drive it till it blows up. My Nissan Murano made it 15 years 250k
This ford ranger is already making me worry. AC issue, fuel censr failure. Do you think these trucks will last or should I sell it while it has value. Just quirious if anyone else's has felt this way?
Can only comment that my'19 @ 29K is with transmission problems - back in the shop now.
Not one problem? Water pump, ball joint, steering shaft. Sounds like 3 problems.
NotBudule2
Robert
21 Ranger
Technical, he's correct I guess ? ? ?, but I am more than willing to trade some reliability for something thats fun to drive, give me a 50000 mile Ranger versus 100000 mile Tacoma any damn day, life's too short to be bored behind the wheel!!!
TomSim
tom
toronto
auto makers need to do away with transmissions completly and replace with a generator that powers one motor on each wheel. just like a locomotive does, think of all the weight loss, transmission, differential, transfer case, drive shafts, c.v. joints and axles. theres got to be a better way
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
Here is the tranny TSB,
TECHNICAL SERVICE BULLETIN
10R80 Automatic Transmission - Harsh/Delayed Engagement And/Or Harsh/Delayed Shift - Non-Main Control Break-In Capable
24-2101
28 March 2024​
This bulletin supersedes 24-2046. Reason for update: revise the Service Procedure LTIS statement
Model:
Ford
2018-2021 Expedition
Transmission/Transaxle: 10R80
2017-2020 F-150Transmission/Transaxle: 10R80
2018-2021 MustangTransmission/Transaxle: 10R80
2019-2023 RangerTransmission/Transaxle: 10R80
Lincoln
2018-2021 Navigator
Markets: Published by Ford North America
Issue: Some 2017-2020 F-150, 2018-2021 Expedition/Navigator/Mustang, 2019-2023 Ranger vehicles equipped with a 10R80 transmission may exhibit a harsh/delayed engagement and/or harsh/delayed shift, an illuminated MIL with DTC P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7 stored in the PCM or TCM. This may be due to the transmission solenoid ID strategy, sticking valves in the main control valve body and/or axial movement of the CDF clutch cylinder (7H351) sleeve. To correct the condition, follow the Service Procedure to identify and correct the condition.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
Parts - All Vehicles - Main Control Overhaul
Service Part NumberClaim QuantityPackage Order QuantityNumber in PackageDescription
W712658-S439​
2​
1​
4​
Solenoid Retaining Plate Bolt
HL3Z-7G007-A​
6​
6​
1​
Solenoid Retaining Clips
JL1Z-7N134-A​
1​
1​
1​
Park Override Bolt (Expedition/Navigator)
XT-12-QULV​
As Needed​
As Needed​
Motorcraft® MERCON® ULV Automatic Transmission Fluid
Parts - All Vehicles - Main Control Overhaul - Parts To Inspect And Replace Only If Necessary
HL3Z-7A191-B​
Only If Necessary​
Only If Necessary​
1​
Fluid Pan Gasket
L1MZ-7A098-A​
Only If Necessary​
Only If Necessary​
1​
Fluid Filter (F-150/Expedition/Navigator/Mustang/Explorer)
HL3Z-7A098-A​
Only If Necessary​
Only If Necessary​
1​
Fluid Filter (Ranger)
7T4Z-7Z302-A​
Only If Necessary​
Only If Necessary​
1​
Transmission Fluid Filter Seal
HL3Z-7J227-A​
Only If Necessary​
Only If Necessary​
1​
Auxiliary Pump Tube O-ring (If Equipped)
HL3Z-7Z490-E​
Only If Necessary​
Only If Necessary​
1​
Chanel Plate
HL3Z-7Z490-D​
Only If Necessary​
Only If Necessary​
1​
Separator Plate (2017 F-150)
JL1Z-7Z490-C​
Only If Necessary​
Only If Necessary​
1​
Separator Plate (Expedition/Navigator With Electronic Gearshift)
JL3Z-7Z490-E​
Only If Necessary​
Only If Necessary​
1​
Separator Plate (Expedition/2018-2020 F-150 Without Electronic Gearshift, All Ranger)
JL3Z-7Z490-D​
Only If Necessary​
Only If Necessary​
1​
Separator Plate (Mustang Built On Or Before 3-Jan-2021)
L1MZ-7Z490-J​
Only If Necessary​
Only If Necessary​
1​
Separator Plate (Mustang Built On Or After 4-Jan-2021)
Parts - All Vehicles - CDF Cylinder Replacement
HL3Z-7G199-A​
1​
1​
1​
Auxiliary Pump Tube Seal (Stop/Start)
HL3Z-7A248-A​
1​
1​
1​
Torque Converter Seal
JL3Z-7N134-A​
12​
12​
1​
Front Support Bolts
LC3Z-7H223-A​
12​
12​
1​
Front Support Bolt Seals
HL3Z-7A248-G​
1​
1​
1​
Front Support To Case Seal
HL3Z-7G091-F​
5​
5​
1​
Input Shaft Seals (F2)
HL3Z-7B399-C​
4​
4​
1​
Sun Gear No. 3 Shaft Seals (F7)
HL3Z-7C099-A​
1​
1​
1​
C Clutch Balance Dam Inner Seal
HL3Z-7A548-B​
2​
2​
1​
C Clutch Balance Dam And Piston Outer Seal
HL3Z-7D404-A​
2​
2​
1​
C And D Clutch Piston Inner Seals
HL3Z-7A262-C​
1​
1​
1​
D Clutch Balance Dam
HL3Z-7D403-A​
1​
1​
1​
D Clutch Piston Outer Seal
HL3Z-7A548-G​
2​
2​
1​
F Clutch Balance Dam And Piston Outer Seal
HL3Z-7A548-A​
2​
2​
1​
F Clutch Balance Dam And Piston Inner Seal
HL3Z-7G091-G​
5​
5​
1​
Input Shaft To Sun Gear No. 3 Shaft Seals (F8)
HL3Z-7G091-C​
1​
1​
1​
Input Shaft Seal (F9)
JL3Z-7H351-B​
1​
1​
1​
CDF Cylinder (F-150/Expedition/Navigator, 5.0L Mustang)
JR3Z-7H351-B​
1​
1​
1​
CDF Cylinder (Ranger/2.3LMustang)
Parts - All Vehicles - CDF Cylinder Replacement - Parts To Inspect And Replace Only If Necessary
HL3Z-7B066-AB​
Only If Necessary​
Only If Necessary​
1​
A Clutch Pressure Plate
HL3Z-7B164-E​
Only If Necessary​
Only If Necessary​
1​
A Clutch Friction Plates
HL3Z-7F220-A​
Only If Necessary​
Only If Necessary​
1​
A Clutch Steel Plates
HL3Z-7B442-F​
Only If Necessary (Ranger Has 4 Pieces, F-150/Mustang/Expedition/Navigator Have 5 Pieces)​
Only If Necessary​
1​
C Clutch Steel Plates
HL3Z-7B164-A​
Only If Necessary​
1​
C Clutch Friction Plates
ML3Z-7B477-A​
Only If Necessary​
Only If Necessary​
1​
C Clutch Pressure Plate
HL3Z-7B442-D​
Only If Necessary (Ranger Has 5 Pieces, F-150/Mustang/Expedition/Navigator Have 6 Pieces)​
Only If Necessary​
1​
D Clutch Steel Plates
HL3Z-7B164-C​
Only If Necessary​
1​
D Clutch Friction Plates
HL3Z-7B066-E​
Only If Necessary​
Only If Necessary​
1​
D Clutch Pressure Plate
HL3Z-7B164-G​
Only If Necessary (Ranger Has 3 Pieces, F-150/Mustang/Expedition/Navigator Have 4 Pieces)​
Only If Necessary​
1​
F Clutch Steel Plates
HL3Z-7B164-D​
Only If Necessary​
1​
F Clutch Friction Plates
HL3Z-7B066-A​
Only If Necessary​
Only If Necessary​
1​
F Clutch Pressure Plate
Parts - All Vehicles - CDF Cylinder Replacement - Select One Of The Following If Needed
HL3Z-7B066-AA​
Only If Necessary​
Only If Necessary​
1​
A Clutch Apply Plate 4.1 - 4.3 mm Selective
HL3Z-7B066-Z​
Only If Necessary​
Only If Necessary​
1​
A Clutch Apply Plate 4.4 - 4.6 mm Selective
HL3Z-7B066-Y​
Only If Necessary​
Only If Necessary​
1​
A Clutch Apply Plate 4.7 - 4.9 mm Selective
HL3Z-7B066-X​
Only If Necessary​
Only If Necessary​
1​
A Clutch Apply Plate 5.0 - 5.2 mm Selective
HL3Z-7B066-W​
Only If Necessary​
Only If Necessary​
1​
A Clutch Apply Plate 5.3 - 5.5 mm Selective
HL3Z-7H032-C​
Only If Necessary​
Only If Necessary​
1​
T-3 Bearing (Replace If T-3 Shim Is Replaced)
HL3Z-7A527-Q​
Only If Necessary​
Only If Necessary​
1​
T-3 Shim 3.05-3.15 mm Selective
HL3Z-7A527-P​
Only If Necessary​
Only If Necessary​
1​
T-3 Shim 3.2-3.3 mm Selective
HL3Z-7A527-R​
Only If Necessary​
Only If Necessary​
1​
T-3 Shim 3.35-3.45 mm Selective
HL3Z-7A527-K​
Only If Necessary​
Only If Necessary​
1​
T-3 Shim 3.5-3.6 mm Selective
HL3Z-7A527-L​
Only If Necessary​
Only If Necessary​
1​
T-3 Shim 3.65-3.75 mm Selective
HL3Z-7A527-M​
Only If Necessary​
Only If Necessary​
1​
T-3 Shim 3.8-3.9 mm Selective
HL3Z-7A527-S​
Only If Necessary​
Only If Necessary​
1​
T-3 Shim 3.95-4.05 mm Selective
HL3Z-7A527-T​
Only If Necessary​
Only If Necessary​
1​
T-3 Shim 4.1-4.2 mm Selective
HL3Z-7A527-N​
Only If Necessary​
Only If Necessary​
1​
T-3 Shim 4.25-4.35 mm Selective
HL3Z-7D483-A​
Only If Necessary​
Only If Necessary​
1​
D Clutch Snap Ring 1.8 mm Selective
HL3Z-7D483-B​
Only If Necessary​
Only If Necessary​
1​
D Clutch Snap Ring 2.0 mm Selective
HL3Z-7D483-C​
Only If Necessary​
Only If Necessary​
1​
D Clutch Snap Ring 2.2 mm Selective
HL3Z-7D483-D​
Only If Necessary​
Only If Necessary​
1​
D Clutch Snap Ring 2.4 mm Selective
HL3Z-7D483-E​
Only If Necessary​
Only If Necessary​
1​
D Clutch Snap Ring 2.6 mm Selective
HL3Z-7D483-F​
Only If Necessary​
Only If Necessary​
1​
D Clutch Snap Ring 2.8 mm Selective
HL3Z-7C122-A​
Only If Necessary​
Only If Necessary​
1​
C Clutch Snap Ring 1.5 mm Selective
HL3Z-7C122-B​
Only If Necessary​
Only If Necessary​
1​
C Clutch Snap Ring 1.7 mm Selective
HL3Z-7C122-C​
Only If Necessary​
Only If Necessary​
1​
C Clutch Snap Ring 1.9 mm Selective
HL3Z-7C122-D​
Only If Necessary​
Only If Necessary​
1​
C Clutch Snap Ring 2.1 mm Selective
HL3Z-7C122-E​
Only If Necessary​
Only If Necessary​
1​
C Clutch Snap Ring 2.3 mm Selective
HL3Z-7C122-F​
Only If Necessary​
Only If Necessary​
1​
C Clutch Snap Ring 2.5 mm Selective
HL3Z-7H365-C​
Only If Necessary​
Only If Necessary​
1​
F Clutch Snap Ring 1.5 mm Selective
HL3Z-7H365-D​
Only If Necessary​
Only If Necessary​
1​
F Clutch Snap Ring 1.7 mm Selective
HL3Z-7H365-E​
Only If Necessary​
Only If Necessary​
1​
F Clutch Snap Ring 1.9 mm Selective
HL3Z-7H365-F​
Only If Necessary​
Only If Necessary​
1​
F Clutch Snap Ring 2.1 mm Selective
HL3Z-7H365-G​
Only If Necessary​
Only If Necessary​
1​
F Clutch Snap Ring 2.3 mm Selective
Parts - F-150/Expedition/Navigator Transmission Removal And Installation
Service Part NumberClaim QuantityPackage Order QuantityNumber in PackageDescriptionNote
7L1Z-4B496-C​
2​
2​
1​
CV Joint-To-Pinion Flange Cup Bolts And Retaining Straps (4WD)
FL3Z-6775-D​
1​
1​
1​
Self-Adhesive Heat Shield
7L1Z-4B496-D​
3​
3​
1​
CV Joint-To-Transfer Case Flange Cup Bolts And Retaining Straps (4WD Expedition/Navigator)
JL1Z-7N134-A​
1​
1​
1​
Park Override Lever Bolt (Non-Column Shift Expedition/Navigator)
FL3Z-5C226-A​
2​
2​
1​
Left And Right Catalytic Converter Gasket (F-150 2.7L)
W520113-S440​
4​
1​
4​
Stabilizer Bar Bracket Nuts
W520114-S442​
4​
1​
4​
Transmission Support Crossmember Nuts
W520514-S440​
4​
4​
1​
Left And Right Catalytic Converter Nuts (All Gas Non-Hybrid)
W704980-S439​
1​
1​
4​
Park Manual Release Cable Bracket Bolt (F-150 Gas/Hybrid)
W709771-S440​
2​
2​
1​
Transmission Mount Nuts
W711140-S901​
3​
3​
1​
Transmission Insulator Bolts And Washers (RWD Gas)
W714418-S439​
4​
1​
4​
Transmission Support Crossmember Bolts
W715131-S437​
1​
1​
4​
Transmission Fluid Cooler Tube Bracket Bolt (Expedition/Navigator)
W715618-S437​
Gas Engines Require 4 Pieces, Diesel Engine Require 6 Pieces​
1 For Gas, 2 For Diesel​
4​
Torque Converter NutsDoes not apply to hybrid
W715798-S442​
1​
1​
4​
Fluid Cooler Tube Stud Bolt (3.0L) / Park Manual Release Cable Bracket Bolt (3.5L)
W716375-S900​
9​
2​
5​
Transfer Case Bolts (4WD)
W718353-S900​
4​
1​
4​
Transmission Insulator Bolts (4WD) (Gas/Hybrid)
W718926-S900​
4​
1​
4​
Transmission Insulator Bolts (4WD) (Diesel)
W715579-S439​
2​
1​
4​
Driveshaft Center Bearing Bolt (If Equipped With Two Piece Driveshaft)
TA-24-B​
As Needed​
As Needed​
Motorcraft® Thread Sealant With PTFE (4WD)
VC-13DL-G​
As Needed​
As Needed​
Motorcraft® Yellow Prediluted Antifreeze/Coolant (All Markets Except Canada)
CVC-13DL-G​
As Needed​
As Needed​
Motorcraft® Yellow Prediluted Antifreeze/Coolant (Canada Only)
XG-1-E1​
As Needed​
As Needed​
Motorcraft® Premium Long-Life Grease
XL-5-A​
As Needed​
As Needed​
Motorcraft® Multi-Purpose Grease Spray
XT-10-QLVC​
As Needed​
As Needed​
Motorcraft® MERCON® LV Automatic Transmission Fluid (4WD) (All Markets Except Canada)Transfer Case Fluid
CXT-10-LV6​
As Needed​
As Needed​
Motorcraft® MERCON® LV Automatic Transmission Fluid (4WD) (Canada Only)Transfer Case Fluid
XT-12-QULV​
As Needed​
As Needed​
Parts - F-150/Expedition/Navigator Transmission Removal And Installation - Parts To Inspect And Replace Only If Necessary
4W9Z-6397-A​
Only If Necessary​
Only If Necessary​
1​
Engine Block Dowel Pins (3.0L)
5L7Z-7D285-A​
Only If Necessary​
Only If Necessary​
2​
Transmission Fluid Cooler Tube Seals (3.0L/3.5L)
5L7Z-7J324-A​
Only If Necessary​
Only If Necessary​
2​
Transmission Fluid Cooler Tube Backing Rings (3.0L/3.5L)
ML3Z-4421-A​
Only If Necessary​
Only If Necessary​
1​
Front Driveshaft Slip Yoke Boot
W701228-S300​
Only If Necessary​
Only If Necessary​
4​
Engine Block Dowel Pins (5.0L)
W718758-S300​
Only If Necessary​
Only If Necessary​
4​
Engine Block Dowel Pins (2.7L/3.3L/3.5L)
Parts - F-150/Expedition/Navigator Transmission Removal And Installation - Rear Driveshaft Bolts And Straps (Not All Vehicles Will Use All Of The Parts Listed)
W500635-S439​
1​
1​
1​
W713095-S437​
1​
1​
4​
Driveshaft Center Bearing Nut (If Equipped With Two Piece Driveshaft)
W719738-S439​
1​
1​
4​
Driveshaft Center Bearing Bracket Mounting Stud (If Equipped With Two Piece Driveshaft)
N800594-S100​
4 Or 8 (Flange Dependent)​
1 Or 2​
4​
Driveshaft Flange To Flange Bolts (F-150)
N811880-S100​
1 Or 2​
4​
Driveshaft Flange To Flange Bolts (Expedition/Navigator)
Parts - Mustang Transmission Removal And Installation
BR3Z-5B266-A​
1​
1​
1​
Exhaust Gasket (5.0L)
W705443-S900​
2​
1​
4​
Catalytic Converter Flange Nuts (5.0L)
W710726-S437​
2​
1​
4​
Selector Lever Cable Bolts
W715131-S437​
1​
1​
4​
Transmission Fluid Cooler Tube Bolt
W715618-S437​
5.0L Require 4 Pieces, 2.3L Require 6 Pieces​
1 For 5.0L, 2 For 2.3L​
4​
FR3Z-4B496-B​
3​
3​
1​
Driveshaft To Pinion Flange Bolts
W719298-S439​
3​
1​
4​
Driveshaft To Transmission Flange Bolts (If Equipped) (2.3L)
N800594-S101​
4​
1​
4​
Driveshaft To Transmission Flange Bolts (If Equipped) (5.0L)
W500545-S439​
3​
1​
4​
W717822-S439​
2​
1​
4​
Driveshaft Center Bearing Bolts (If Equipped)
TA-25-B​
As Needed​
As Needed​
Motorcraft® Threadlock and Sealer (Convertible)
XL-1​
As Needed​
As Needed​
Motorcraft® Penetrating and Lock Lubricant
XL-2​
As Needed​
As Needed​
Motorcraft® High Temperature Nickel Anti-Seize Lubricant
XL-5-A​
As Needed​
As Needed​
XT-12-QULV​
As Needed​
As Needed​
Parts - Mustang Transmission Removal And Installation - Parts To Inspect And Replace Only If Necessary
5L7Z-7D285-A​
Only If Necessary​
Only If Necessary​
2​
5L7Z-7J324-A​
Only If Necessary​
Only If Necessary​
2​
JR3Z-4782-B​
Only If Necessary​
Only If Necessary​
1​
Flex Coupling Driveshaft
Parts - Ranger Transmission Removal And Installation
JB3Z-4B496-B​
6​
6​
1​
CV Joint-To-Transfer Case And Pinion Flange Bolts And Retaining Straps (4WD)
BE8Z-6731-AB​
1​
1​
1​
Engine Oil Filter And Gasket (4WD)
KB3Z-6L612-A​
1​
1​
1​
W500121-S437​
9​
3​
4​
W500642-S437​
4​
4​
1​
Transmission Support Insulator Bolts (4WD)
W700056-S450B​
2​
1​
4​
Selector Lever Cable Bracket Bolts
W714265-S442​
3​
1​
4​
W715618-S437​
6​
2​
4​
W716936-S442​
2​
2​
1​
Stabalizer Bar Bracket Nuts
W719427-S439​
2​
1​
4​
Stabalizer Bar Bracket Bolts
W710233-S437​
4​
4​
1​
Driveshaft Flange To Pinion Flange Bolts
W714780-S439​
2​
1​
4​
W716344-S437​
4​
4​
1​
Driveshaft Flange To Transmission Flange Bolts
PM-4-A​
As Needed​
As Needed​
Motorcraft® Metal Brake Parts Cleaner (Compliant With Low Volatile Organic Compound Requirements As Required In Some USA States)
PM-4-B​
As Needed​
As Needed​
Motorcraft® Metal Brake Parts Cleaner (Not Compliant With Volatile Organic Compound Requirements)
XL-2​
As Needed​
As Needed​
XL-5-A​
As Needed​
As Needed​
XO-5W30-Q1SP​
As Needed​
As Needed​
Motorcraft® SAE 5W-30 Synthetic Blend Motor Oil (All Markets Except Canada)
CXO-5W30-LSP6​
As Needed​
As Needed​
Motorcraft® SAE 5W-30 Super Premium Motor Oil (Canada Only)
XT-10-QLVC​
As Needed​
As Needed​
CXT-10-LV6​
As Needed​
As Needed​
XT-12-QULV​
As Needed​
As Needed​
Parts - Ranger Transmission Removal And Installation - Parts To Inspect And Replace Only If Necessary
JB3Z-7J227-A​
Only If Necessary​
Only If Necessary​
1​
W701183-S1300​
Only If Necessary​
Only If Necessary​
4​
Engine Block Dowel Pins (2.3L)
Claim Quantity refers to the total number of individual pieces required to repair the vehicle.
Package Order Quantity refers to the amount of the service part number package(s) required to repair the vehicle.
Number In Package refers to the number of individual pieces included in a service part number package.
As Needed indicates the amount of the part may vary and/or is not a whole number. Parts can be billed out as non-whole numbers, including less than 1.
Only If Necessary indicates the part is not mandatory.
Warranty Status: Information Only.
Repair/Claim Coding
Causal Part:IN
Condition Code:42
Service Procedure
NOTE: This article is for information only. Determine the causal part number and use available labor times in Section 7 of the SLTS Manual or claim M-time in accordance with the Warranty and Policy Manual. Causal part number IN in this article refers to the information only status and is not able to be claimed.
1. Using the latest software level of the appropriate Ford diagnostic scan tool, check for DTCs.
2. Are any of the following DTCs present? P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7.
(1). Yes - proceed to Sticking Valves - Main Control Valve Body Step 1.
(2). No - proceed to Transmission Solenoid Strategy Step 1.
1. Reprogram the existing transmission strategy download into the PCM/ TCM. Refer to WSM, Section 307-01.
(1). For FDRS applications when prompted, select Transmission hardware was not replaced - Reprogram TRID strategy for the existing transmission.
(2). For IDS applications when prompted, select Reprogram Only-No Hardware Replaced.
2. Perform the adaptive learning drive cycle. Refer to WSM, Section 307-01.
3. Does the vehicle still exhibit the condition after performing the adaptive learning drive?
(1). Yes - proceed to Sticking Valves - Main Control Valve Body, Step 1.
(2). No - repair is complete.
NOTE: Advise the customer this vehicle is equipped with an adaptive transmission shift strategy which allows the vehicle's computer to learn the transmission's unique parameters and improve shift quality. When the adaptive strategy is reset, the computer will begin a relearning process. This relearning process may result in firmer than normal upshifts and downshifts for several days.
NOTE: Affected vehicles are not main control break-in capable.
1. Overhaul (clean and inspect) the main control valve body and perform the adaptive learning drive cycle. Refer to WSM, Section 307-01.
2. Does the vehicle still exhibit the condition after overhauling the main control valve body and performing an adaptive learning drive cycle?
(1). Yes, vehicles built on or before 15-Aug-2022 - proceed to CDF Clutch Cylinder Replacement Step 1.
(2). Yes, vehicles built on or after 16-Aug-2022 - this article is complete. Refer to WSM, Section 307-01 for normal diagnostics.
(3). No - repair is complete.
NOTE: Advise the customer that this vehicle is equipped with an adaptive transmission shift strategy which allows the vehicle's computer to learn the transmission's unique parameters and improve shift quality. When the adaptive strategy is reset, the computer will begin a relearning process. This relearning process may result in firmer than normal upshifts and downshifts for several days.
NOTE: For Mexico, U.S. and Canadian vehicles which are low time in service (LTIS) policy eligible, the dealer has the option to continue with this TSB repair or replace the transmission under the LTIS policy.
1. Remove the transmission and mount the transmission to the bench. Refer to WSM, Section 307-01.
2. Disassemble the transmission. Perform only the necessary steps to remove the clutch and planetary assembly from the transmission case. Refer to WSM, Section 307-01.
(1). It is only necessary to remove the torque converter, transmission fluid pan and gasket, transmission fluid auxiliary pump (if equipped), fluid filter and main control valve body assembly, all 4 speed sensors (intermediate speed sensor A [ISSA], intermediate speed sensor B [ISSB], turbine shaft speed [TSS] and output shaft speed [OSS]), transmission fluid pump, front support assembly and the clutch and planetary assembly. Refer to WSM, Section 307-01.
3. Disassemble the clutch and planetary assembly. Perform only the necessary steps to remove the CDF clutch cylinder and the No. 3 sun gear shaft and No. 2 ring gear assembly from the clutch and planetary assembly. Refer to WSM, Section 307-01.
(1). It is only necessary to remove the A clutch assembly, the selective shim and T3 thrust bearing, remove and discard the 5-input shaft front seals.
(2). Remove the No. 1 planetary carrier snap ring, clutch, and planetary container cylinder, the E clutch and input shaft assembly, the No. 3 planetary carrier and No. 3 sun gear, the No. 3 sun gear shaft and No. 2 ring gear assembly. Refer to WSM, Section 307-01.
4. Remove and discard the sun gear No. 3 shaft seals. Install the 4 new sun gear No. 3 shaft seals. Refer to WSM, Section 307-01.
5. Disassemble the C, D and F clutch assemblies from the CDF cylinder. Discard the CDF cylinder. Refer to WSM, Section 307-01.
6. Assemble the C, D and F clutch assemblies into the new CDF clutch cylinder. Refer to WSM, Section 307-01.
7. Perform the C, D and F clutch pack endplay measurements for proper clearance. Refer to WSM, Section 307-01.
8. Remove and discard the input shaft-to-sun gear No. 3 shaft seals. Install the 5 new input shaft-to-sun gear No. 3 shaft seals. Refer to WSM, Section 307-01.
9. Remove and discard the input shaft seal. Install the new input shaft seal. Refer to WSM, Section 307-01.
10. Install the 5 new input shaft front seals. Refer to WSM, Section 307-01.
11. To reassemble the clutch and planetary assembly, reverse the disassembly procedure. Refer to WSM, Section 307-01.
12. Perform the T3 thrust bearing measurement to set transmission front end clearance. Refer to WSM, Section 307-01.
13. Reassemble the transmission. Refer to WSM, Section 307-01.
14. Install the transmission. Refer to WSM, Section 307-01.
15. Perform an adaptive learning drive cycle. Refer to WSM, Section 307-01.
Why do they list a different part# for the Ranger transmission filter?
theprinceofsnj
Richard
Clayton NJ
2019 Ford RangerXL 1959 Edsel Villager 9 passenger
I'm way behind I only have 68000 going on 69000. No real issues. I do miss my 1997 XLT. 2.3 5 speed-manual. Lost that one with 249,995 miles and over 21 years of virtually trouble-free driving. The one thing I do wish my 2019 had is a manual transmission.
diesel924
Dan
Ellington, Connecticut
2019 Ranger Lariat, 2020 Escape
Fire truck mechanic, EMT
Can you access the oasis reports? I bought mine used from a non ford dealer and would really like to know if it had anything done being as I’m the third owner.
Check your DM's.
Friday yet?
‘23 Lariat Tremor, Focus ST
Well, I have my maintenance spreadsheet already laid out to 250K. Laugh if you will but I'm confident.
Hell, my previous POS (Frontier NISMO... '06 if memory serves) made it to almost 190K. (Dumped it in 2013 for a Focus ST.) But god knows I replaced everything other than major drive train components on that bitch. It was in the shop regularly. Both before and after warranty expired. Only got rid of it because I could "feel" something (transmission maybe? Can't describe it.) wasn't right so I cut my losses.
If that POS made it to almost 190k, my Ranger will do 250K.
Light_seep
2021 ford ranger
108k miles on my 2021 i bought new. No issues at all. Just general maintenance. Have faith lol
JHC14
Joel
Baker, LA
2019 Ranger Lariat 4x4, 2017 Escape Titanium
Executive Pastor
My 2019 Lariat is at 107,018 and there has not been any major issues. I just changed my original plugs last month, brakes, regular oil changes and I have changed the EGR DPFE sensor twice. I got mine with 21k on it in May of 2020. It has run like a champ ever since I bought it. Now watch it blow up tomorrow. Thanks for that!
I really like mine and would buy another tomorrow if I had too or could. I am not a FORD ONLY type of guy, but I do like my Ranger.
