1ST Tire Rotation
Warren
Warren
New Berlin, Wisconsin
2019 Ranger Lariat,
Having all the necessary equipment to regularly rotate tires as I have done for many years, I performed my 1st Ranger rotation yesterday. Seemed strange one lugnut on each axel was extremely tight compared to others with removal using standard impact gun. I only use a quality torque wrench set to the factory recommended 100 ft lbs for reinstallation. On the last wheel install and torque one of the wheel studs snapped. Apparently a defective stud. Heading into the dealer shortly. Don't know how difficult it will be but I assume it will be covered.
Also changed oil for 1st time. If you use an oil filter cap wrench to install the Ford recommended Motorcraft FL-910S filter don't assume it will fit the factory filter. It does not!
JDCinVA
Vienna, VA
2019 Ford Ranger, 2013 Ford Explorer, 1977 BMW R100/7
That sucks! I hate when simple jobs go south like that.
MINI Ranger
Gene
2019 Ranger Lariat FX4, 2014 MINI Cooper S Clubman
ASE Master Technician, MINI Technician, Retired
So the factory filter is different than those sold by Ford as a replacement? That's just not right!
NickTheEnforcer
Anthony
Northern Illinois
I'd be shocked beyond belief if they actually 'covered' it...
NickTheEnforcer
Anthony
Northern Illinois
GregsFX2Ranger
Greg
2021 XLT 302A 4x2 Rapid Red Black Appear Package
Management
76MM 14 Flutes is the exact cap that fits the 910S. Mine is a Steelman cap.
It removed the factory one, and one was not needed to reinstall it by hand.
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
Filter sockets come on a set cause there are several sizes.
GregsFX2Ranger
Greg
Management
It is a different filter (OEM), but its still 76mm and 14 flutes.
this is the original filter in the picture.
Joeiconic
yeah, they will say you over-torqued it. Another good reason to just let the dealer do routine maintenance. They break it, they fix it. You break it, you fix it.
I avoid Fram and Purolator filters like the plague! JMO.
Wix, Hastings, Bosch and surprisingly Motorcraft filters score really high and are pretty damn solid to work with..not as flimsy as others on the market. NAPA filters last time I checked were Wix rebranded...
I'm with you Nick...I've since moved on to OEM filter...a whole lot cheaper at $4 per filter...
Radioman
Kent
Roseville, CA
Oh good, another filter discussion
GregsFX2Ranger
Greg
Management
What is wrong with the Motorcraft FL-910S?
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
I have a filter wrench with retractable claws, it grabs anything.
