$189 Transmission Flush + Filter. ....for real?
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
That is a big ask. Phone camera will be a bit obvious. ....maybe I can find a hat cam.
You can do it. Tell the service personnel that you are so happy with their service that you want a photo to post on this forum and then take a photo of her first then leave.
harringtondav
East Central Iowa
....says the man that told me " No more shenanigans mister. ....thinking I could learn a lot about shenanigans from you. ;)
LUBEGARD® Platinum® Automatic Transmission Fluid Protectant can be added to any ATF (except CVT, and Ford Type F [1986 and earlier models]). For normal applications, add 1 oz. (29.6 mL) of LUBEGARD® Platinum® to 1 qt. (1 L) of ATF for the total capacity of the transmission with motor idling. DO NOT OVERFILL. Always consult your owner’s manual for vehicle specific instructions. To determine fill capacity, use our OM ATF & Conversion Chart
I just bought a 15oz. bottle and dumped it all in.
5thranger
Gary
kansas
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
I swear to god, I'm going to pistol whip the next guy that says shenanigans!!!.....
seanellaz
Sean
Tucson, AZ
Healthcare
I stopped by dealer yesterday to swap Ford semi-syn oil for their full syn engine oil.
I stopped at the service desk to talk to the manager about a flush for my 10R80. He was busy, but his assistant is hot, hot. So I asked her. Some lower price for a dump, filter, refill. $189 for a flush + filter. Blink, blink. I asked her for the price using their flush machine. $189.
They say if it is to good to be true, it probably isn't.
Thoughts please.
It'd be way cheaper if Ford had put a drainhole in the pan.
harringtondav
East Central Iowa
I've heard about an aftermarket metal pan with drain hole/plug on this forum. I'm considering getting one for the shop to swap out....if I can find that post.
seanellaz
Sean
Tucson, AZ
Healthcare
I installed the deep PPE pan with drain hole. Super happy with it.
harringtondav
East Central Iowa
Thanks, I'm on it.
I've found two sources for this. One is a few bucks more for their 'deep' version which is good for me with the extra fluid capacity. ...good for cooling, etc.
Question if it will clear the skid plate/cross members and match up with the pump intake.
...any thoughts?
Thanks, I'm on it.
...any thoughts?
No need for the extra capacity. Stick with the standard depth and you will be fine. The cooling fins will be more than enough to help with cooling. Also having the drain plug makes it real easy to service the transmission
OGMix376
Bryan
Service center at the dealership I got my truck from… said $350.00 for a fluid exchange (no filter change) ? they call that a transmission service… well it is “A” service, but not exactly what would call a “Transmission Service”…
Being a sarcastic fellow at times..
I said so when you change the oil on a vehicle do you not change the filter?
The lady (she was polite I admit.) replied oh sir actually on these newer vehicles the transmission doesn’t have a filter. ?
I just said I’m pretty sure it does but ok thank you for your time…
Got a call back and a fluid, filter, pan, and gasket.. Will hit me for $650.00
