110V Outlet Not Powering Device
Zetterbeard
Zach
2020 FORD RANGER XLT 4X4
Bought one of these air purifiers for the Ranger, but with the truck on and it plugged in to the 110V outlet it will not power on. Is there any reason this should not work? Checked the fuse and it looked fine. The yellow light next to the outlet is on, so I assume the outlet is working fine.
BiilyJones
2021 Ranger
Heavy equipment operator
Try the purifier in your house.
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
How many watts does it draw. Have you tried anything else in the truck to be sure the outlet is live.
Joeiconic
Did you get a spec sheet with the product? How much power does it require? The 110v outlet in the Ranger is very limited.
Dereku
Chicagoland Area
Could be bad. Mine was so loose nothing would charge or stay plugged in. Dealer replaced it in 2 minutes while I sat in the truck.
Zetterbeard
Zetterbeard
Zach
Can't seem to find it now, but I believe it only draws about 5W, so should be fine. Should almost any accessory work in the outlet? Like if I plug my cell phone charger in to the 110V outlet should that work and test the outlet?
Joeiconic
yes, that should work.
Fordup
Ed
NY
youtube.com
Something like a night light should show if it's working.
It’s limited to 150 watts…
Zetterbeard
Zetterbeard
Zach
Cell phone recognized the charger immediately, so the outlet is working.
Found the documentation for power draw. 3.5W, so I am not sure why it isn't working.
Brett Fields
Brett
Brooklyn
Paramedic
That inverter is modified sine wave. (vs pure sine wave) Things with motors will be hit or miss.
i wonder if the air purifier has a short some place or a problem with its plug.
