10r80 dead. 110k miles. Ford sucks
MyLittleRanger19
MyLittleRanger19
Andrew
Princeton, TX
2019 Ranger STX
Electrical Engineer
Trans pan's on my list too...good choice...
ppe or mishimoto? im leaning towar mishimoto because i know their R&D process is legit. and +2Quarts seems like a good idea
I would go with the PPE Standard Pan over the PPE Deep Pan and Mishimoto Pan. Why? Because the extra 2 quarts won't make a difference. The PPE Pan does have a drain plug that works well and cooling find that will assist to an extent on Transmission Cooling.
MyLittleRanger19
MyLittleRanger19
Andrew
Princeton, TX
2019 Ranger STX
Electrical Engineer
hmmm ill keep that in mind. i do like the fact that the mishimoto doesnt use the stock gasket but instead a highly superior oring design. i hate gaskets. like a lot.
Make sure the surface is clean and all the bolts are torqued correctly including the correct sequence if applicable and you should be fine.
Let's say you get the Mishimoto pan and later down the road it decides to leak. Better yet Mishimoto discontinue that pan and no longer carries that o-ring type gasket. What are you going to do then? You going to be screwed and required to get a new pan and gasket
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
Yea, whichever is cheaper and floats your boat. The PPE holds about 3/4 qt more fluid, but in reality, we don't really need it.
As for gaskets, I do like the o-ring one, but when it leaks where's the replacement coming from in 5 years when they stop making the pan?
The Ford gasket is actually quite nice and a little o-ring like. Also reuseable.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Bead of rtv in the old gasket grove. I did it for an old ppe pan on my 7.3. Worked amazing.
Someone please make a sub $100 sump pan with a drain...that's all I need and want...
Maybe I should start another vendor challenge?
Is the Ford gasket sold separately?
ctechbob
Shawn
Adult Daycare
