Worse m.p.g. Using higher octane
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
CB750F
Qc
Human
is this mythical 30hp gain available through any range of use, or is it only when the computers determine its worth, ie: while towing up a steep slope on a hot day?
it would be embarassing to offer a performance tune that makes an extra 45 horsepower when 30hp of it is from a required octane change alone.
@RANGER PRIDE
LOL, no idea, I've seen no proof, just the internet... lol.
As for your second part, would not be the first time someone sells
snake oil.
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
Just for your own information. 2017 f150 ecoboost government research. 32.8 mpg on 93 octane, 32.5 mpg on 88 octane on high way conditions. IF cost/mileage is your only concern, get 87oct. Now if you want the extra power then 91+ oct. I don't know all the slight engine differences and if we would get different results but it's worth something at least.
https://www.nhtsa.gov/sites/nhtsa.gov/files/documents/812520.pdf
Motorpsychology
Prescott, WI
Vagabond
I’m currently running 91 because of the hot summer months here. The manual recommends 91 during hot temperatures use. As soon as it cools off I’m switching to 87. 91 prices has been killing me.
I get better performance and milage on my Suzuki V Strom (V-twin 650cc) with 91 oct than with 87 oct. The main reason I do is because 91-oct is the only no-ethanol fuel in my area, and my Butt-O-Meter detects an improvement in performance, real or imagined. Besides, I get 60+mpg so the extra ~70¢/gal. doesn't amount to much. In my Ranger, I fill with premium if I will be towing, and/or driving 75-80 in hot weather or hilly terrain.
91 octane: 32.8mpg X 18 gallon fill= 590.4 mile range vs 87 octane: 32.5 mpg X 18 gallon fill= 585.0 mile range so it's not worth it to me to run premium all the time in the Ranger.
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
The ECU measures knock and adjusts the timing accordingly, it's the kind you won't really hear, low magnitude.
The ECU does not have a octane sensor input, it is all done with knock feedback, which is VERY different than pre-detonation that you can hear, the best power is right on the edge of knock, it is most efficient at that point as well.
I found that the big difference in mileage and power between fuels is the brand, Chevron is good for both, Shell not so much, cheap 7-11 or off brand fuels feel like 87 octane instead of 91, but here in California we have the some of the worst fuel, full of additives and ethanol, it gets worse when we get the winter blend, mpg will drop 2-3 on that stuff.
BassRanger
Al
Oklahoma
Goodyear
..... the best power is right on the edge of knock, it is most efficient at that point as well.
This is incorrect. Best power and efficiency is made at maximum brake torque or MBT. Assuming you have enough octane to reach this point, further advancing timing to the point of knock will not gain you anything.
Fitzmotor
Gold Sponsor
Saugus
I knew somebody would comment on my comment, I should have mentioned at peak torque.
But, when you are on edge of knock AND into knock you can make the most power and economy, once past peak torque you can knock it even harder.
In the Indycar and prototype engines, they would run them into knock which yields peak power, it was down to knock hits per mile, (150-240 mph) at 4-6 knock hits per mile the engine would last, jump to 20-30 knock hits per mile for qualifying or end of race push, it would start to erode away the pistons like a nitrous motor.
The power gains were huge, we would start to reach up to 14+ MPA cylinder pressure, once we figured out how to control the knock with the added power we had to beef up the rod, rod bearing, piston and pin as well as thicker valve heads and chamber casting thickness.
But it was a interesting development, in the beginning the knock would turn into auto ignition, they could not shift the cars as the engine was in glow plug mode and would not shift cut.
So I know the normal thought is knock is bad, but knock and pre-ignition are not the same, most of what a person hears is pre-ignition, a uncontrolled ignition event, knock is different, it occurs at the right time, it's just a violent combustion event due to uneven fuel in the chamber, it would be the intake side of the piston that would start to glow as there is little fuel/space between the intake valves and the piston at full valve lift, so once the valves close that part of the chamber is very lean, that side of the chamber would experience the knock, we could measure the cylinder pressure in different places during testing. Chevy had the advantage on us as their DI injectors pointed at the intake side where ours pointed at the exhaust.
Sorry I got so carried away, flame propagation in a chamber can be interesting but a nightmare too, I should go into GCI where gasoline/ethanol engines run without a spark plug, they light upon knock, probably would have been the latest technology for road cars but EV's are taking over the world anyways.
Fitzmotor
Gold Sponsor
Saugus
I got really carried away with that post, sorry.
The point is the mfg can get power gains with increased timing through knock feedback, they have good enough technology and materials to keep it alive closer to the knock edge.
So many people don't understand octane, but I'm not directing this at you.
The higher the octane, the lower the propensity for the fuel to burn before desired, or precombust. Standard compression and heat is enough to make lower octane fuel precombust (burn before it should based on the position of the piston/valves due to heat) which would be a knock if the engine didn't adjust for it - which leads to crappier mileage. Conversely, there is a point where a higher-octane fuel becomes moot and doesn't make any difference as long as it begins to burn 1-6 degrees before top dead center of the piston and the valves are all closed. FWIW, mid-grade fuel wherever we're all at is fine. 87 octane in Colorado (mid-grade) is the same as 91 octane (mid-grade) in Cali because of the altitude. I get the same mileage on the 87 here (Colorado) as I do running the 91 (Premium). While towing across the State, I'll run 91 due to engine load. Wherever you're at, you only need to run mid-grade fuel because turbo. The extra compression will precombust lower-grade fuel.
Another common misconception is that diesel has a higher octane rating than gasoline. Diesel has an octane rating of 25-40 because it uses compression/heat only to ignite the fuel.
There is a f-ton of science that goes into air/fuel ratios and octane ratings for engines and it is interesting to me.
I live in Colorado. Your equivalencies are off. Due to altitude (less oxygen less propensity to combust) 85 is equivalent to 87, 87 is equivalent to 89, and 91 is equivalent to 93.
Nobody in their right mind puts premium in their car just for an MPG increase. Especially when prices are this high. Higher octane is for safety and performance.
Higher octane allows for advanced timing without knock or predetonation. If you're tuned, real custom tune not OTS, on premium you should run premium. Even stock Ford's knock sensing system will advance timing.
Also, why did you quote me if "you're not directing this at me."
It IS interesting, and complicated. You should study it some more. It's exactly the opposite of what you think. Turbo = premium.
Edit- this was in response to a post by @FordFreak
Must've got deleted or something.
Gsxrdoug
Hawaii -- Oahu
2021 ranger, XLT 4x4, Cactus Gray
Therapist -- Retired Navy
What was the question?
FordFreak
2020 Lariat FX4 Ranger, 2022 Sonata Limited
Mid-grade is fine for a little turbo like these. Noticeable difference in my blown Mustang (with a "real custom tune") though. I'd quoted you because I didn't feel like scrolling to the end of the thread to make a post. I deleted my post so you could feel superior about my equivalencies of octane being wrong though. It used to be right until they phased out MTBE in 2003. Everything else you wrote was what I said. You just used different words. Congratulations!
CB750F
Qc
Human
I love fresh octane in the morning.
