Wheels + Offset + Tire Size Thread Pictures
Scooterdog
Don
SE Wisconsin
I showed my wife a Jeep the other day with bronze wheels and she agrees that my Ranger would look nice with that color (almost and okay to buy?). So, I am looking at these: AR201 - American Racing
The size I am looking at is 18x9" with a 35mm offset. I will be using 265/65/18 Toyo AT IIIs (on the truck now with the stock black package wheels).
What do you guys think?
I just mounted a set of these exact wheels along with BFG KO2s in 285/65/18. My Ranger is blue, and the dark bronze wheel color looks great! (American’s photo is deceiving, the bronze color is much darker in person) I’ll get some photos up in a day or two…
TORQUERULES
US
Ranger
I would love to see those.
Scooterdog
Don
SE Wisconsin
If that is with a 285, then my 265/65/18 tires should be fine. How is the overall clearance with those 285s?
I’m on a 3” lift in front, 1” rear. They clear ok. Your 265s should be a perfect fit. I bought the wheels from PerformancePlusTire.com. They had a good price and they were in stock.
Thinkofsomethingkwik
Hugh januse
Alberta
2022 Roush Ranger
Lineman
Kind of reviving a dead thread here, but here goes. I've got a 2020 fx4 lariat with stock suspension. I'm looking at getting a 265/70/17 tire and pairing it with a 20mm offset black rhino rim. Will this run on the crash bars at all w/stock suspension.
Thanks for any and all help
Here
XLT
Installed my new tires and wheels today! KMC 17 x 8, 20mm offset and 5 Falken WildPeak P285 70 17 tires.
The 2nd to last Pic at the shop is the stance with the oem tires and wheels.
I still need to do some detailing but I managed a wash and meguiars tire shine foam.
I still have 2 3/4 inch clearance for the garage so I will install the last 1 inch spacer in the front next week and adjust the speedometer.
Came across this somehow today and Jeezaloo Mike, every time I see your truck, I am struck by how gorgeous it is. You deserve to be proud of all of that really great work! ?
Here
XLT
Boy, that’s a tough call without at least a 2” front level. You might be fine but many folks who went up to that size were on stock wheels and had levelling shocks or a level kit. It’s the offset of the aftermarket rims that raises questions for me. Worst case scenario, you need to lift the front end with coil overs or a kit. Shop charges on either are about $500, plus the parts.
I hope it works for you because it will look great and hopefully, someone on here has done this exact setup and has the answer.
Fawnbuster
Indiana
Retired 34 years as LEO
Thanks Duke! You're the best!
Fawnbuster
Indiana
I would hit Discount tires up on here, forgive me but it's been a while and I've deleted our msgs so i dont know his name, but they have a PC program that can answer nearly every question you have. After I told them I replaced tbe UCAs and swapped out my crash bars for readybuilts and the front leveling kit I was installing they knew the parameters that would fit for any combo's. They researched a supplier who found my rims in the color and style I wanted then he knew what offset to order them in and what size tires would fit. I was ecstatic ! I'm old school I don't care for big gaudy wheels and skinny tires even if it gave me the stance I wanted. I bought my truck with 18" wheels but discovered I could get more sidewall protection for my wheels, a slightly wider stable stance and ride comfort they helped me zero in quickly on the size tire then it was personal preference on tire specs and looks. I wanted 3 peak tires for road, mud and snow a bit aggressive look but pretty quiet and very comfy for my liking. The sound deadening I installed also made them more quiet. There's my 2 cents worth. Hope it helps
P.s. after all that the only rubbing I discovered was backing out of my slightly sloped driveway and turning the wheel nearly all the way I had a minor rub on the front plastic splash guards, I took them off and cleanly trimmed them along the factory crease and reinstalled them, you can't even tell I trimmed them and zero rub.
Fawnbuster
Indiana
Oh and once we found rims we liked we created a profile on the discount tire website and were able to see the wheels on a stock look 2019 screw in saber.
