jflogerzi
Moreno Valley, CA
You are holding extra heat in the turbo. The stock valve blows off lower to dump the heat for turbo life and electronics controls the mixture that would probably need to be changed during the cycling. That would probably need to be changed for the swap for the different curves. I would like to see Ford engineering take on this mod before making it. It's not sensed progressively so that makes me suspicious. Did you ask your dealer about warranty and emissions changes this could affect?
no damage honestly... just bean counters at work... plus metal is better/stronger for this part.
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Is that your opinion or Fords reply to the question. I think test data should be approved by ford engineers on mods to the blow off points should warranty issues result longterm.
In honor of Soupie, my State's registration stickers are Race Red! =p
Also got an inch longer arm for the phone holder, It's still well below the hood line (no visual obstruction of the road) and it fully clears my tiny center screen, plus my fingertips reach the phone while hands are on the wheel (but not when spinning the suicide knob whipping around the dump - woohoo!). =D
And some cable management clips that will surely fall off (in addition to IPA, I also have some 3M Tape Primer 94 pens).
I can see myself possibly changing to the ball thing that bolts to a support under the vent ...
Bluelounge CableDrop Mini and JOYCOURT Car Cable Clips
not in the mail mail, but via email today
Jhbryaniv
2023 Ranger Tremor
I keep a couple different size arms in my center console.
I find it annoying when the phone is on the longer arm and bounces on rough roads, but when it's in the short arm it gets hidden behind my hand on the steering wheel...
I'll post a couple pictures in a bit when I take the kid to school.
My mount is actually higher than yours, it sits on top of the climate control vent there. I can dig the link to the product if anyone wants it I've posted it before it's an Australian company I can't remember the name of. ?
Jhbryaniv
2023 Ranger Tremor
I finally bit the bullet and bought t nuts from 80/20 that are the size I need for the yakima tracks. I've been using Amazon and knock off tnuts that are close to 40 series than the 45 series the yakima is close to...
These little sucker's aren't cheap, from anywhere that I could find. I figured I'd buy direct from 8020 to make sure they weren't knock offs...
Jhbryaniv
2023 Ranger Tremor
Colo_Ranger
2021 Ford Ranger XLT FX4
If you ever don't want to wait for your parts to be mailed, I've bought from Torpey's Denver before. Prices seemed in line and I can just go and get what I need.
Jhbryaniv
2023 Ranger Tremor
That's the right hand drive version, but yes. ? They install with existing hardware and just use the ram mount or similar fixture.
MY only issue is that the metal is a little flimsy when you put a pixel 7 pro in a heavy case in a ram mount holder at the end of a ~4-6" connector thingie....and it compounds when you use the adapter to add 2 devices to the ram mount... ? If I still had my 3d printer I'd print a wedge back there to make it more stable...
Ohh, now that is going to be a fun place to go. ?
Jhbryaniv
2023 Ranger Tremor
Speaking of enablers - it's less than 20 minutes from the house... ? ? ?
Here's a slightly different approach and also bolts to the support behind the vent:
https://coursemotorsports.com/colle...mount-ford-ranger-2015?variant=44623398895922
Note: there's a model for those w/o navigation, like Soupie because where we're going, we don't need roads (i.e., the dump) and a model for you fancy pants peeps with navigation. =p
with nav
no nav
Jhbryaniv
2023 Ranger Tremor
with nav
no nav
That's a nice solution. Might be a good choice to put on the passengers side for her phone...
That's my mount with the ram mount for 2 devices. When I run it this way, I normally have my GPS up there too... Eventually that will go away and I'll have a Garmin inreach mini up there...
The only issue, I think, is that the stock one has a 17mm ball, but for $15 they have a 20mm ball (also have a 25mm).
My Off-Roam is 20mm .... and yours might be too.
Jhbryaniv
2023 Ranger Tremor
Sorry, I only speak American measuring system.
My balls are 1 inch... They aren't the biggest, but they are robust...
