Video of the Ranger Production Line at MAP
That was pretty interesting. I thought it was interesting that they put the badging on (the XL/XLT/Lariat badge) on the fender before putting the fender on. Those big welding robots were pretty cool too.
Thanks for posting it.
djg1958
Livonia, MI 48154
2017 Lincoln MKX
I believe that the fenders are already on. I think what you are seeing is plastic protective body cladding.
ajvester
Chicagoland
Toyota Tundra
Yes, that is a fender protector to prevent panel/paint damage on the line.
One of the interesting parts for me was the inspection robots at final line. If you skip to 1:55, you can see what looks like a machine vision system inspecting the A-Pillar and cab corners. I worked in production control for an auto manufacturer 15 years ago and our systems were nowhere near that advanced. Automated inspection has come a long way.
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
Yes, that was cool. Thanks for posting!
jcardona1
CA
'14 Toyota 4Runner Trail edition / '04 Nissan Frontier / '96 Toyota Land Cruiser
Fascinating stuff. Amazing how the human workers barely have to lift a finger.
I figured that is what those were - pretty neat to see all the automation and robotics in action.
DHMag
Dale
San Antonio, TX
The frame turnover looks to be a constraint. When my dad worked at GM Arlington, frame turnover was done on the fly via rotisserie while in motion from upper level to lower level. Also, body marriage is not as sophisticated at GM's procedure.
But cool nonetheless !
FLEngineer
Orlando,FL
2019 Ford Ranger Lariat SCrew
Cool, now we need an enhance button like they have on CSI so we can match some of the VINs to members.
gfitzge2
Gregg
Louisville, Kentucky
Retired Electrician
Many of those jobs are much harder than they look. VATs (Vehicle Assembly Technicians) are good at what they do and make them look easy. Yes they have a lot of hoists and balanced load assist devices to help them do their jobs and reduce injures but they still require skill and finesse. Plus, even an easy job done 70 times per hour 10 hours a day is pretty stressful on the human body. That's one reason some jobs are automated using robots and other automation. Often Dirty, Dull, Difficult and Dangerous (the 4 Ds) jobs are prime candidates for robots to do. But having said that, humans are still a major part of the process. For example the Super Duty plant in Kentucky employs about 8500 people and about 1600 robots.
Also modern robots even the huge ones lifting entire bodies are so precise and repeatable that they can be used for intricate work like you see here.
That is a good look inside a modern auto assembly plant. Most auto companies use the same tooling manufactures to build their plant equipment so what you see here is pretty similar to any Ford, GM, FCA, Tesla etc. plant.
These plants are truly engineering marvels.
Pinecrestjim
Pinecrest, FL
I wish that video was 30 minutes in length, showing the entire process - stamping, painting, and more details in assembly. Obviously, intrigued and enjoyed it.
gfitzge2
Gregg
Retired Electrician
Here is a video of the Ford Expedition assembly. It is just some short clips but gives you a little more of the processes in an assembly plant.
gfitzge2
Gregg
Retired Electrician
My favorite part is at the 128 mark where the hoist operator is decking a cab but is looking at the monitors and not the hoist she is controlling. Also of note is the green colored robot which is a "collaborative" robot and is working right with humans without cages or guarding. That's fairly new technology.
FordBlueHeart
Torr
Traverse City, MI
2006 F250 King Ranch 6.0l
Collision Repair Estimator
Hmmmmmm, I wish that any physical job I've ever had would allow me to wear sweatpants. Might as well be pajamas.
technological_marvel
Evan
New Hampshire
2019 Shadow Black Ranger LARIAT FX4
Hi all, I found this the other day and thought it was pretty cool to see what goes into the assembly process. I'm not sure if this has been shared but I didn't see anything in the quick search I ran before posting.
edit: your truck could be in this video! pretty neat.
