TSB 20-2277 2019-2020 Ranger - Shudder/Vibration When Accelerating From A Stop
TSB 20-2277 Poll
  • Total voters
    200
Milkmaster
Milkmaster
Alcatraz
2020 Ranger
Question for Phil Schilke…. I had the TSB done to adjust pinion angle. It made it better but not fully fixed. I noticed that shudder is nearly negligible when you don’t stomp on accelerator and it is worse when you are an incline. I also recall reading a comment where a user upgraded springs to help fix start up shudder in an F150. Got me thinking, is it possible that the shudder comes back because the rear leaf is so flexible that you get torsional rotation of the axle upon acceleration, basically creating an excessive pinion angle? That may explain why so many rangers have it. I’m wondering if upgraded leaf springs would improve/fix it?
I have had thoughts along these same lines. The rear end really flexes the leaf springs during acceleration more than I would have expected or have seen before on other vehicles.
jamo147
Connecticut
2020 Ford Ranger XLT
i have about 300 lbs in the bed right now lowering the bed. That improved but didn’t get rid of shudder initially. I did this because previously I observed that when the bed was loaded with 500 pounds, it fixed it. I initially attributed this to the lowered ride height/pinion angle. Recently after reading a reply to this thread that someone put 140 lbs at the front of the bed to fix shudder, I moved the weight more toward the center/front of the bed. The shudder is now almost gone so that is supporting that it’s a combo of excessive static pinion angle and axle torsion. Now the challenge will be replacing with springs that are stiffer but don’t raise the bed height since that may screw up the pinion angle again.
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
I added spacers to the center carrier bearing for the driveshaft yesterday. This has greatly reduced the start-up shudder... it's not completely gone, but it's much, much, much better. Barely feel it at all any more.
I wound up using a stack of grade 8 washers and new, longer stainless steel bolts. Here are some pictures.
Before:
After:
Willis
Kentucky
2022 Ranger Tremor XLT
My truck started shuddering at about 33k and it went to the shop today. They said it would take minimum two days to fix. Is this the normal time range?
Willis
Kentucky
Update it only took about an hour and didn’t help it at all. Not very happy.
navsnipe
Rockland County, NY
It's odd that your shuddering didn't start until 33k miles. Did you recently do any suspension work to the truck? Most trucks that have the shudder come with it. Is the shudder only at take-off, around 10 to 15 mph?
Willis
Kentucky
Nope totally stock. It’s at about 30 to 45 mph is the worse. But highway driving is normal. If I am in town it is terrible. Been totally happy with my truck as I have had many Rangers in past and my dad has also. He still has his 97 splash in the garage lol. But to have the mechanic verify it is fixed when it isn’t really has made me down. I don’t want to keep running to the car lot as I like everybody else just doesn’t have the time.
navsnipe
Rockland County, NY
I would suspect this isn't the same take-off shudder that TSB 20-2277 covers. As much as you don't want to have to go back to the dealership you will probably have to. Make sure a tech does a ride along with you so you can show when and where the problem happens. Do you have a description of the work they did recently?
Willis
Kentucky
Yea they drove the truck and I rode with them before they did the tsb.
quangdog
Kimball
Meridian, Idaho
www.youtube.com
30-45mph? That's definitely not start up shudder. More likely you have an issue with a wheel that threw a weight and is no longer in balance correctly.
Super odd that they would have applied that tsb (which specifically addresses shudders when first starting from a stop, not when cruising) after riding with you and feeling the behavior.
It's incredibly frustrating to me that the people who are supposed to be qualified to address concerns with these trucks seem not to be at all. :-(
ChiefQM
Bill
Hiram, GA
2019 Ford Ranger XLT
I am a slow convert to the start up shudder not being my issue. I have had techs and shop foremen ride with me and tell me that even though what they feel in my truck is the worst they have ever experienced with the bucking and shaking while steady in a gear (not shifting), the truck was operating as designed and neither their shop nor Ford was going to pay them to work on it. I gave up on them even attempting to find the problem. As suggested elsewhere in this thread, when I start the engine, I put it in tow mode (and strangle the auto start feature), That holds the trans to shifting later, and the engine rpms are kept to about 2000 RPM, and the issue has virtually gone away. I am assuming you have a tow package, obviously. Hit the button on the side of your shifter and you can see that the trans is not shifting to 8th gear by the time you hit 30 mph. If I am going to drive over 40 mph and at highway speeds, I take the tow mode off. And they did the TSB (wrong, but they did it) to shut me up.
Willis
Kentucky
I plan on getting my wheels and tires balanced tomorrow. I hope this helps.
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Has anyone tried for shits and giggles removing the rear leaf blocks (but keeping one on the drivers side to compensate for the lower left side) that came stock with the truck, which would lower the rear and see if that fixes vibration issues? I had vibration issues since stock but not terrible. After my 3" eibach leveling struts, its bad.
