quangdog
- First Name
- Kimball
- Joined
- Mar 31, 2020
- Threads
- 33
- Messages
- 684
- Reaction score
- 2,199
- Location
- Meridian, Idaho
- Website
- www.youtube.com
- Vehicle(s)
- 2019 Ranger Lariat FX4
When @P. A. Schilke says "start up shudder" - he means when accelerating from a stopped position, not when starting the engine of the truck.I thought it was about shudder when taking off/accelerating from a stopped position, not starting up the vehicle. I didn't know there was shudder when people start their trucks.
My truck exhibits this start up shudder behavior... here is my best description of the sensation:
Let's say I'm driving normally down a road with a speed limit of 40 mph. Truck is smooth while cruising, only feeling typical road sensations. Drivetrain is fine. Approach a stop light, and slow to a stop. As soon as the truck stops completely, the engine shuts down with the auto-start-stop feature. So now I'm sitting at a stop light in stealth mode - engine not currently running, just waiting for the light to turn green. When the light turns green, I let my foot off the gas and the engine immediately starts again. This produces a VERY NORMAL shudder in the truck as the engine starts - no problem, completely expected. Then my foot gets over to the accelerator pedal, and I pull away from the light with easy to moderate throttle input. Up until the truck hits about 7 mph the drivetrain is perfectly smooth, but between 8ish to 15ish mph, I experience a "shudder" in the drive train that *feels* exactly like the way the truck shudders when the engine starts up as described above. As soon as I'm moving faster than 15 mph, the shudder disappears.
The stronger the throttle input, the stronger the shudder, but the shorter the duration (because I accelerate faster).
As Phil said, if you feel a vibration while cruising at any constant speed above about 15 mph, it is NOT due to this "start up" shudder. This shudder is specifically caused by driveline angles being slightly out of spec, and is very common with 2 piece drive shafts, and specifically happens when accelerating from a stop somewhere around 10-15 mph.
I tried to get my truck into a dealer, but had a terrible experience with the service advisor lying about loaner car availability and misunderstanding / incorrectly documenting the actual issue I wanted checked. Attempted to drop the truck off once, but wound up leaving the dealer astounded with how I'd been treated. Just living with the shudder... but it bothers me.
Currently planning to attempt shimming the center bearing myself, just as soon as I have a spare few minutes to do so.
Mine is a 2019 Lariat FX4, with about 13k miles on the clock now. The shudder has been there since day 1, and was not altered at all by installing a 2" front leveling kit (Eibach) and new rear shocks (also Eibach).
I'm 100% convinced the root cause is driveline angles. I'm also 100% convinced none of my 3 local(ish) Ford dealer service departments will apply the TSB correctly.
