Transmission fluid level check
Jmckinley
Southern Ohio
Ford C Max, 2019 Ranger XLT SuperCab, Kawasaki VX 300, Mazda Miata, Damon Motorhome
Retired Engineer
Does anyone here know if the engine should be running while checking transmission fluid? Shop manual is unclear. It says start engine, warm up the transmission, then check the dipstick. Doesn’t mention shutting off the engine.
Jmckinley
Southern Ohio
Retired Engineer
yes.
I know they dont say to keep it running, but they also dont say to shut it off either.
That’s the way I read it. That’s good, it will keep the cat hotter so will make playing with the dipstick more exciting.
Jmckinley
Southern Ohio
Retired Engineer
By the way, I’m pretty sure mine is at least 2 qts low. Other Ranger, F150 and Mustang owners have reported low ATF as delivered. I wonder if that explains some total transmission failures on trucks being flat towed behind motor homes?
Muscleford
George
Ohio north coast
Retired CFO
Where is the transmission dip stick?
Down under the truck on the side of the transmission. Very close to the exhaust. So checking it hot is an adventure. Ford did not intend for the transmission to be an owner serviceable item. Basically a sealed unit with a 150K change interval.
Jmckinley
Southern Ohio
Retired Engineer
Except, they forgot to fill some of them properly. It only holds 6 qts so 2 qts low is a big deal.
Dahveed
Central Kansas
Pharmacy Consultant
Gloves, long sleeves, and a flex head ratchet make checking the transmission fluid a breeze.
Utope
Jacob
2021 Cactus Grey XLT SuperCrew FX4
Electrical Engineer
I think you would also want to cycle the shifter through reverse and drive to fill the channels. Then put it back into park and check with the engine running.
outdoorphotog
Ian
Healdsburg, CA
2019 Lincoln Navigator L
Limo Driver
Welding gloves worked for me - make sure it’s also ACTUALLY at the correct temp. It’s hard to get above 207F for me unless I try to get there
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
I subscribe to the method that FordTechMakuloco uses.
Check the fluid cold with the engine running and make sure it is at the very low end of acceptable (Between 4 and 5 IIRC). When it warms up, it will be where it is supposed to be.
That or spend $200 on the B&M dipstick.
https://www.youtube.com/c/FordTechMakuloco
Mentioned in this vid:
