Transfer case service
highway
steve
kentucky
2020 ford ranger xlt
How many quarts of fluid does it take to service the transfer case ?
thank you
The answer actually brings conflicting data:
Owner's Manual = 23.67 fl oz's
Service Manual = 1.20 qts or 1.13 lit - and yet another states 1.20 lit
So bottom line = Fill to Spill and have about 1.5 qts (ready)
highway
steve
kentucky
Thank you thats what i was looking for but could not find it in search
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
thank you
Don't worry just fill it until it comes out the hole. How much to buy? A couple of litres should be plenty, I've done mine but can't tell you exactly because I pumped it from a 5 litre bottle of Transmission fluid. Don't bother to buy new plugs either, even though Ford say toss them and buy nice new shiny ones pre-covered with teflon sealer. Just buy a tube of Loctite 592 or similar and clean and re-use your existing ones.
diesel924
Dan
Ellington, Connecticut
2019 Ranger Lariat, 2020 Escape
Fire truck mechanic, EMT
The drain plugs for the trucks in NA have one-time-use crush washers. No sealer is used. My wife's Escape uses sealer on the PTU (basically a transfer case) so maybe Australia uses the same set up?
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
That's interesting ours uses tapered plugs with sealer, although there is a machined face around the plug hole so you could also use a crush washer if you had a flanged plug.
highway
steve
kentucky
Just looked and my 2020 has the washers
