transfer case drain and fill bolt torque
silverflash
Bill
NC
2021 ranger XL loaded
stuff
anyone have a page with these values? the factory manual here in the sight has a link for the transfer case but when you unzip, everything is 0 bytes.....
Radioman
Kent
Roseville, CA
2020 Ranger Lariat SuperCrew 4x2, 2017 Toyota Limited Highlander w/Platinum Pkg., 2012 Jeep JK Rubicon
I don't know the specs for Ford Ranger but for my other vehicles I use about 20-25 ft lbs. They just need to be snug enough to not leak.
Zvedza
'21 Ranger Tremor, '04 SVT Lightning, '16 ZX-10R
Looked it up on the forum and found a guy who had the same issue with you and tq'd it using the rear diff tq spec with no issue (20ft-lb)
as a comparison the f150 raptor the rear diff fill is 22lb-ft and the listed tq for the transfer case fill/drain is 133in-lb (11ft-lb), id like to venture and say theyre similar, but i cant say for sure.
They both use the 10r80, but not sure on t-case similarity.
Could technically find the tq by using a tq wrench and slowly increase the tq to see what turns it.
Probably 10lbs...it felt like the aluminum threads would strip with ease if I'd kept going...
Langwilliams
Langley
Lorain, Ohio
German spec works just fine for me
I've had bad results from my "goodantight" German torque wrench. Something like those plugs snug is good enough for me, I just check it a few days later for signs of leaking.
Crown Forklift Technician
Really depends on what bolts and how far your "Goodantight" is if you ask me. Some don't know where to stop and keep going. Others stop way to early and have big problems.....
Langwilliams
Langley
Lorain, Ohio
I figure anything that takes a 1/2" or larger socket can handle more than I can dish out at my age.
Bravohook
Addame
Victor
2021 Ranger XLT FX4
Sheepdog
I use the German spec sheet values of Gudentite
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
I worked on Hyundais for too long with their recycled metal crap bolts to rely on feel alone. I like my electric torque wrench. The warning beeps as you get close then the screaming when you reach it is nice IMO.
There is a reason why KIA Hyundai are piles of junk
silverflash
Bill
NC
stuff
I used the same 1/2" Rachet with the hex bit to snug just a hair. Went back with torque wrench and it clicked at 18 ft lbs. So not sure if the drain and fill plugs are too tight or not. If I had to guess I'd say low to mid 20s. Thought abt loosening them and using the torque wrench for the whole thing but then the washers need replaced I guess and that's a problem with the drain plug as I'd lose all my new fluid. Thoughts? Let it ride or undo them and retorque using same washers?
