- First Name
- Steve
- Joined
- Jul 1, 2021
- Threads
- 84
- Messages
- 6,073
- Reaction score
- 30,328
- Location
- Fishersville, Va.
- Vehicle(s)
- Previous 2021 Ranger, Now 2019 Ford Expedition
- Occupation
- Navy Vet., Retired Police Sgt., Grumpy Old Senior Citizen
I've seen several posts and online info indicating the platform is a class 3 and some indicatingf its a class4.....the weight rating that Ford places on it indicates a class3.....7500/750 equates a class3.Where are you getting that the hitch is a Class III, I'm fairly sure Ford states it's a Class IV. Ford does not state that WDH is required for max towing on the Ranger, if it were a Class III that required that I'm sure they would state it somewhere. They clearly state in the towing guides that F-150s require WDH to tow over 5,000lb.
Class 4 hitch platform's are usually rated for towing 10-14,000 lbs with a tongue weight of 1000-1400 depending on the use of a WD or not.
I will grant you that the Ranger hitch is a substantial one, probably capable of more than it's listed capacity....but probably based more on the Rangers capability than the hitch..
Without a WD setup the entire tongue weight is bearing down on the hitch itself which is only 4 bolts. The addition of a WD setup transfers weight removing some to the vehicle itself.
Personally, without a WD setup I would limit my personal use to 4000 lbs and 500 lb tongue...but thats just me.
No, it is not "written" but almost any of the hitch manufacturers will have listings for their platforms with a WD set up and without. You just have to dig a bit to find info.
